76Hawke
I'm cutting into my brake lights, turn signals, and running lights for a license plate brake light and turn signal indicator, top Box lights and turn signal indicators, and a helmet light and turn signal indicator, as well as adding a strobe device for The top Box and license plate only.
In addition I installed a USB port into the Frunk and it has an attached voltmeter and inline fuse. It comes with battery ring terminals To hook up straight to the battery. If I go to the accessory sub harness will the Volt meter still read accurately, or should I go to the sub harness, and if I do should I get rid of the fuse? Or should I go straight to the battery? Hmmmm...
Am I correct in understanding that I should take both the wires for the running light and the plate light for the aftermarket license plate holder and hook them up to the same wire on my bike ( Pink and blue in my case for 2015 Manual)?
Lastly, I'm adding some Apollo heated grips. They also seem to be intended to wire directly to the battery with an auto shut off if the voltage drops too low. I'm wondering again if I should go directly to the battery or tap into the sub harness, which already has the relay kit and fuse installed as well.
TLDR: If my farkles appear intended to wire directly to the battery and have auto shut off features as well as voltmeters and inline fuses, should I run them straight to the battery instead of the sub harness?
And since the license plate holder that I am installing calls for running lights and a license plate holder wire, should I just attach both of those leads to the same wire in the rear of my bike?
Thanks A ton for reading, I wish brevity was a stronger suit of mine.
