16DCT
It's time for a valve adjustment/check on my 2016 NC700X D.
Do you typically remove the spark plugs for this job or do you leave them in?
Ah, that's good to know. Funny enough I just hit 57,000 miles last night, but I haven't checked on the condition of the spark plugs yet.I do not remove the spark plugs.
I think technically the compressible gasket on the spark plug is designed for one time use, but that is debatable. Regardless, I do the valve adjustment just fine without removing the plugs, so I see no point doing the extra work of removing and reinstalling them.
The plugs last a long time. I think mine have been removed and inspected once in 57,000 miles.
The owner’s manual (my 2012) maintenance schedule recommends spark plug inspection every 16,000 miles / 25,600 km, and plug replacement every 32,000 miles / 51,200 km.Is there a replacement interval for spark plugs or is it an inspection and replace if needed?
I pull the plugs & inspect if only for fear of the steel plugs seizing in the aluminum cylinder head. Admittedly that hasn’t happened on any Honda I have owned and only once in my 50 years of fiddling with machinery.
Honda is specifying the same spark plug replacement interval for the NC’s partial iridium plugs as they are for my ‘02 Goldwings copper plugs. I think it may just be their habit and/or standardization of maintenance intervals.Why do bike makers state such short change intervals for plugs.
The last few cars I've had have said to replace the plugs at 100,000 miles.
But my bike needs new ones at 30,000 miles - why??
The Goldwing spark plug replacement, at least my '08, is at 16,000 miles. The NC is 32,000 miles.Honda is specifying the same spark plug replacement interval for the NC’s partial iridium plugs as they are for my ‘02 Goldwings copper plugs. I think it may just be their habit and/or standardization of maintenance intervals.
To your point about cars. Yes, I replaced my car plugs at 100,000 miles. It runs a little lower RPM than the NC, but not a big difference. I think Honda’s motorcycle replacement interval is too frequent, as I suggested earlier, my own experience is that the spark plugs in the NC appear to be fine for double the time Honda suggests. To each his/her own. There is no right or wrong, just more hassle or less hassle, whichever you prefer.
By the way, if an owner wanted to save money on plugs, and wants to do the replacements at 32,000 miles, we established on the forum long ago, through a reputable source, that the Goldwing 1832cc engine plugs are usable in the NC, and cost much less than the iridium plugs.
If the Goldwing plugs are the exact match to the NC's Iridium plugs, then why wouldn't Honda spec the Goldwing plugs for the NC in the first place?By the way, if an owner wanted to save money on plugs, and wants to do the replacements at 32,000 miles, we established on the forum long ago, through a reputable source, that the Goldwing 1832cc engine plugs are usable in the NC, and cost much less than the iridium plugs.
Thanks for setting me straight. I looked it up and you are correct. I guess I said 32,000 mile Goldwing (1832cc) plug replacements earlier because I chose to double the Goldwing’s interval, just as I have with the NC.The Goldwing spark plug replacement, at least my '08, is at 16,000 miles. The NC is 32,000 miles.
I don’t know. I just heard that it works and has been done. I think the old posts about it have disappeared with forum software changes.If the Goldwing plugs are the exact match to the NC's Iridium plugs, then why wouldn't Honda spec the Goldwing plugs for the NC in the first place?
There must be a legitimate reason if the size, gap, and heat range are identical.
Personally I wouldn't do it.
Not sure that theory has merit because even with old bikes with electronic ignition:That is why I changed at 32k with the hope that the coils will last longer and the duration of the spark will insure proper combustion.
