Replacement Wheels/Alternative?
Ghostknight119
Lebanon
Hello :) My bike was hit in the front by a texting driver and the wheel was slightly bent. Tried fixing it at multiple shops but now the front wobbles when i'm braking. The wheel and the brake disk need changing.
The wheels aren't available in my country and i can't seem to find them on bikebandit or ebay.
Can anyone recommend a replacement model?
Mine is a 2013 NC700X manual transmission.
Thanks guys!
I don't have much help for you. I found that the CTX700 also fits, but I dont know if that bikes parts are available to you.
You probably already knew this since the bikes are so similar, but I couldn't be certain.
Good luck.
Are you sure the wheel is also bent or only the disk?
The CB500x uses the same wheels.
I guess the car driver has to pay, just order somewhere outside your country.
