I just replaced my 4 year old battery after a lot of waffling. It shows no signs of weakness, the bike starts and shifts ok, but it is 4 years old. Checking around, Yuasa's cost $120 and up, aftermarket no name brands start around $30 or $35. Finally I took my own advice and called a friend with one of those cheaper electronic load testers. These work by measuring internal resistance and thus the amount of sulfation and indirectly the battery's capacity. I got big bold, all capital REPLACE.
Looked long and hard at those cheap batteries. Amazon showed almost 15% of over 2000 reviews that were 1 and 2 stars. A couple that said their battery arrived damaged in shipping sold me, because I've been a victim of Amazon's crappy packaging. I bought a Yuasa from a MC accessory place in Colorado.
Replacing the battery is not difficult...well, it should not be difficult. Removing the two screws and heavy factory wires from the old one is straightforward and easy. Unhooking that rubber strap is a horse of a different color. The top plastic 'hook' is just the right size for the metal loop, it is out of sight, and I think it tends to hold that metal bail when you are able to stretch the strap enough to unhook it. After a bit of sweating, I was finally able to release the strap.
Pulled out the old battery, charged up the new one fully, and slipped it into the pocket. Attached the two leads. And then began a half hour struggle with my wife helping to reattach that cursed rubber strap. The 'hook' is just about the same size as the metal bail and you have to slide that bail in perfectly. You cannot see what you are doing, and fighting the tension of the rubber strap to give you enough slack took nearly all my hand strength. There is minimal clearance atop the battery and fingers barely fit into that space. This 'hook' is below the fusebox so you cannot get to it from the seat side of the frunk (I had all of the fairing off when I did this). I eventually succeeded, you should expect a bit of a struggle.
Fusebox: Removing the lid is a bit problematical. The cover has a tab on the right side of the bike that you need to push inward (toward the fusebox) while pulling up on the cover. It will hinge up and out and unhook from the left side. Since the entire frunk and fusebox are black (and light absorbing), you cannot see what to release until the cover is off. This too is more difficult than it needs to be. I'm considering cutting the tab off and using a piece of electrical tape to hold the cover closed.
