I would be more concerned for the function of that bolt in retaining and aligning the end of the clutch cable. The broken fastener is one of two that retain a bracket that holds the end of the clutch cable. When you pull the clutch in and release it does the bracket move around in any way? I have a DCT and there is no bracket on my bike to investigate.That's a huge relief for a noob like me. Thank you dduelin!
I actually happen to have a 1300-mile trip to Turkey, where I will do my 12,000 km check.
Do you think I could wait that long?
The clutch holder is moving a bit, when I pull clutch in. So in this case, I was thinking of tensioning the cable a bit more. Would that be a good idea?I would be more concerned for the function of that bolt in retaining and aligning the end of the clutch cable. The broken fastener is one of two that retain a bracket that holds the end of the clutch cable. When you pull the clutch in and release it does the bracket move around in any way? I have a DCT and there is no bracket on my bike to investigate.
And for sure it must be done before leaving for your trip!I have no problem drilling and re-tapping bolts, but I'd be wary doing it myself in something both critical and expensive. If it were me, I'd think it might be a good time to pay someone competent to do it.
No, removing the play in the cable lever by tightening the cable could cause the clutch to slip with all those resulting problems.The clutch holder is moving a bit, when I pull clutch in. So in this case, I was thinking of tensioning the cable a bit more. Would that be a good idea?
Heeey, I did that to my bike too! Helicoils are awesome though ...fortunately I'd knackered the thread from an engine mount in an area which had enough meat to be repaired - by someone more professional than IIf you try to save money installing crash bars your own and not have a torque wrench, you might also have the pleasure!![]()
You’re heading out on a long trip. Get it fixed correctly now-much better than having to deal with an issue on the road. Any problems you can avoid Before a road trip are good things to do ( tires, brakes, etc.). If anything is “iffy” fix it at home where you know the dealer/mechanic and can pick and choose when and where to do the work. On the road you can find yourself at the mercy of who ever happens to have the parts/skills you need. Most folks are decent and helpful, but there are always some who’ll take advantage of your problem if they can…@ LearnedButt and melensdad: I was actually thinking about to try a removal kit, before giving if over to the service guys.
Have to decide I guess, if I let things go and let them do it. Or I try doing it...
