Shinko 705 - 150/70 Rear and 130/80 Front on DCT bike
north6633
Oregon
I have been searching the forum, but I have not been able to confirm if this combination will work on a 700X DCT. I don't know why it wouldn't, but I was curious if anyone has tried it on a DCT. I see where it has been used on a non-dct. Is there a max change from the stock tire diameters that the DCT will start to throw faults? This combo is almost the same size front and rear with a 3mm difference and the stock is a 26mm difference. I haven;t found any information on the limit, other than the mention that the DCT will malfunction if the tires are out of spec., but no mention of what that the max difference can be.
Thanks
New Commuter700
San Tan Valley, AZ
nc700xcommuter.com
That tire starts with more than 10/32 of an inch of tread (about 8mm). The difference between stock and the 150/70 is about 9mm. If the DCT had a problem with a different tire size than it would appear whenever you get low on tread (or when you first put these on). Granted the stock tire started with about 2/32 of tread but many people are running the Shinko's with a larger diameter. As for the front, I doubt there would be a problem there because the VSS does not run off the front.
north6633
Oregon
Thanks for the response. I did not know if the DCT used the front tire size in its operation. Or the difference between the front and rear tire size would effect it. I have not been able to find any info regarding this or even anything saying the DCT through a fault other than a post that said it could. Nothing saying "I had these tires and the DCT failed".
So I am assuming as widely as these ties are used they aren't a problem, since I can find anything that says there is a problem. This being the internet, there would be a complaint somewhere if it were the case. :)
