76Hawke
So I picked up a pair of Cyclops Pegasus auxiliary lights, and the skene IQ 275-A controller. I don't have the Honda accessory sub harness, but I'm thinking about adding it if I don't use a different fuse block or an m-unit . I was hoping to do the fuse block or sub harness as a winter project, and for the time being I was hoping to just add the auxiliary lights hooked up to the IQ 275a straight to the battery for fall driving.
Does anybody have experience with this that they'd be willing to share?
I mounted both of the lights, and wired them to the controller. I took both of the lights and grounded them to the frame, as well as the black lead from the controller.
I now have a white wire that I am supposed to tap into my high beam. I also have a red wire that calls for me to tap into a switched power source.
Can anyone break down for me what that switched power source would be, and where I would best tap into both the switched power source, and the high beam? Thanks again for any help, and I'd be grateful to answer any questions that might help with the process.
Also, is it silly that I'm hesitant to use positaps?
Thanks in advance
Thanks in advance
