salishmoto
I'm not finding anything on whether the 21 NC slipper clutch is also a gripper clutch? The light lever pull seems to imply it would be since the springs are weaker. Does anyone here know for certain? Thanks.
I understand your curiosity. However, my 2012 NC has nothing but a simple multiplate wet clutch. It works 100% fine and I never thought it needed any more complexity.Thanks. I meant to post this in the 750 technical. It's ambiguous with these clutches as some slippers are only slippers and some are grippers. The NC doesn't make too much power, but the only reason to have lighter springs is if the gripper function is present since upon acceleration the gripper pulls the plates closer together without the need for stronger springs. Doubt anyone has taken one apart yet. Maybe I'll look up a replacement part and that may tell me. I'm just curious.
Slippers were initially designed for the track, where you want to keep pushing things as hard as you can and a slight foul-up could be a major problem. I think mostly from there, engineers decided they could use lighter clutch springs if they put these slip/assist clutches on street bikes. I'm assuming it's mostly the "assist" and not the "slip" that makes them desirable for street use, though the "slip" feature would still provide a bit of an extra safety net for those people who think that getting a 1400cc sportbike as soon as they get their license is a smart choice...Thanks again. Aside from any performance benefits, which I agree may be minimal, the main benefit is that this is going to be my wife's bike and the lighter clutch pull really helps her. She gets tired hands and forearms easily. Even on my 1400cc sport bikes with regular clutches I never had a problem popping my rear tire loosed on down shifts. Who is that careless?
I doubt you'd see increased life for two reasons:My mechanical mind is interested in the gripper function because it would seem to extend clutch life. With a mechanical pressure forcing the plates together firmly instead of mere springs, it would stand to reason that they would be held more firmly and resist slippage as they wear.
