SOLD Givi Trekker luggage and mounting hardware for 16-20 Honda NC700x / NC750X
steveinky
Covington KY
Givi Trekker luggage and mounting hardware for 2016-20 Honda NC700x / NC750X. $700 for everything, located in Covington KY.
Items: Givi Trekker 52 litre top case,
(2) Trekker 33 litre side cases,
Givi M5 monokey mounting plate for topbox,
Givi PL1146 Sidecase mounting hardware,
Givi 1146FZ arms for rear rack mount
The hardware should fit 2016 -2020 Honda NC700X/NC750X. This was all mounted on a 2016 Honda NC700X. The 2016 has the same body work that was used on the 2017 – 2020 NC750X. These brackets will not fit the 2012 -15 NC700X and I believe does not fit 2021 models. Check the Givi site for your year. This is everything you need to set up a NC700/NC750. The side cases can be used as clamshell or top loaders due to the way they are hinged.
