GLC
I purchased a Stop & Go Tubeless Puncture Pilot kit (see photos), which uses the mushroom type plugs. I chose this kit because a) it comes with a small electrical air pump with built in pressure gauge for accurate reinflation of the tire after repair, and b) it doesn't require the perhaps messy application of glue as used with the strip type repair kits. Able to pump up to 50psi I thought it can also do double duty for my car tires too. I got this from Amazon and it promptly arrived, but on inspection I found that the nozzle, which does double duty, first on the tire probe tool and then on the plug insertion tool, would not screw on to the latter. I put this down to a one-off bad thread on the plug insertion tool, and rather than send the whole thing back, I called the number clearly posted on the packing and spoke to John in Illinois, asking whether he would send me another plug insertion tool rather than me return the whole thing to Amazon for a replacement. He agreed and a new insertion tool promptly arrived. Unfortunately this replacement has exactly the same thread issue, in that the nozzle will not screw on to it more than a quarter/half turn. Clearly something is amiss here. I will be back on the phone to John on Monday morning, but meantime the point of this post is to see whether any other forum members have had the same experience with this kit. The materials, made in Taiwan according to John, seem of good quality steel, not plastic, so it is a shame about this thread issue.
