rpvanoyen
Hi there,
Before I'm building (altering) the additional electrics on my bike, I like making a schematic plan in advance. That way any improvements can be made during planning, which occurs up to three times on most occasions. I like to share the plan as I have it in mind now.
The switch box is made out of ABS, mounting it to the battery access panel on a rubber backing and holding it in place with the standard rubber string. All wires from and to the battery area are lead through one rubber grommet in a drilled hole from the edge of the frunk. This way the switch box can always be moved out of the way if maintenance desires this, also the rubber seal on the panel will not be compromised. In the longest side there are 4 switches of which 3 are illuminated by a small LED when the switch is on (orange for the battery charger, yellow for future flood lights and green for GPS power). The 4th switch has no built-in LED and is for the frunk interior lights.
I use heat shrink crimp connectors (Faston), heat shrink crimp and solder wire connectors and crimp wire ends (added shrink tube if needed). The main wire boom is hold together with a spiral tube, the two wires for the frunk lights will be captured in closed tubing. Probably next week I can start with the switch box, it can be fabricated whole and connections/switches tested before going live on the bike.
