Rabbit
I caved on my valve inspection at 15376 miles… the struggle is realI caved under the intense emotional pressure of seeking peace of mind. Only made 7744 miles on the oil change.
Sending that oil to a lab, such as Blackstone, would be informational.I caved under the intense emotional pressure of seeking peace of mind. Only made 7744 miles on the oil change.
That's it ... we're doomed. One of the seven signs of the Apocalypse; frogs and locusts; cats and dogs playing with each other; Democrats and Republicans going to the movies together. The End Times are upon us.I caved under the intense emotional pressure of seeking peace of mind. Only made 7744 miles on the oil change.
Blackstone Laboratories Blackstone Laboratories
Learn what's going on in your engine with oil analysis. Our free kits are easy to use and we explain the results in plain English!www.blackstone-labs.comMotorcycle | Blackstone Laboratories
Motorcycles often see different use than cars and trucks. Use analysis to determine problems in the engine and transmission, the optimal oil change interval, and more!www.blackstone-labs.com
I have a Blackstone sample kit sitting on my workbench, thinking I would test my truck’s oil. However, I’m not really inpressed with this report, so I’m having second thoughts. The comments just talk about the engine’s state of wear. I will want to know primarily comments about the condition of my oil after so many miles or so much time. That’s why I’m sending in a sample, to test the oil. Can Blackstone even tell the difference between oil that’s been used 1,000 miles vs 10,000, or do they just look at the amount of fuel, antifreeze, water, and metals found?My last report suggested going to 9500 miles for next oil change. I might take it to 10,000, easier to remember. I had about 82,000 miles on engine when tested.
As I see it, engine wear is a direct correlation to the performance of the oil and the comments are relative. I’ve had other Blackstone reports where comments discussed oil shear which is indicated by the viscosity part of the report. And ya, they have to go by your reported miles and can’t judge mileage on oil, just how the oil is performing based on a large database of average values. The Blackstone website and BobtheOilGuy websites go into more detail. This was my first test on this bike but the thing to do is retest the same bike as time goes on, Then the discussion goes to how your engine is wearing as mileage over the years increases. The reports are not an end-all, tell-all but can give you a heads up if something is going on. Rotella for the win , but ya, it would be interesting to compare against the recommended oil.I have a Blackstone sample kit sitting on my workbench, thinking I would test my truck’s oil. However, I’m not really inpressed with this report, so I’m having second thoughts. The comments just talk about the engine’s state of wear. I will want to know primarily comments about the condition of my oil after so many miles or so much time. That’s why I’m sending in a sample, to test the oil. Can Blackstone even tell the difference between oil that’s been used 1,000 miles vs 10,000, or do they just look at the amount of fuel, antifreeze, water, and metals found?
I also noted that you are not using an oil type or viscosity recommended by Honda for the NC series engine, but of course, an owner is free to choose.
This has been helpful and enlightening. I want to send in an oil sample that has been in an engine 3 or 4 years, to see if it is any different than an oil that’s been in an engine 1 year or less. I had no intention of telling them the time or mileage on the oil. That is what I want them to tell me. It appears Blackstone cannot help me with my quest. This discussion saved me $35.As I see it, engine wear is a direct correlation to the performance of the oil and the comments are relative. I’ve had other Blackstone reports where comments discussed oil shear which is indicated by the viscosity part of the report. And ya, they have to go by your reported miles and can’t judge mileage on oil, just how the oil is performing based on a large database of average values. The Blackstone website and BobtheOilGuy websites go into more detail. This was my first test on this bike but the thing to do is retest the same bike as time goes on, Then the discussion goes to how your engine is wearing as mileage over the years increases. The reports are not an end-all, tell-all but can give you a heads up if something is going on. Rotella for the win , but ya, it would be interesting to compare against the recommended oil.
Same..With computer AI, FI engines are very fuel efficient to HP output. They even let the owner know when it's time for any maintenance.
I run full synthetic in all my engines, big and small, except the NC DCT; I stick with standard GN4 10W-30.
Many ST1300 owners and myself ran Rotella, which actually is the recommended oil for diesel engines.I’m sorry. I thought you had posted previously that you use 5W40 Rotella in all your ICE engines. Faulty memory on my part. Must have someone else.
I also ran Rotella 15w40 for a long time in my ST1300. Something like 70 or 80,00 miles. Honda allowed 15w40 in that bike.Many ST1300 owners and myself ran Rotella, which actually is the recommended oil for diesel engines.
Rotella T4 &T6 are currently JASO-MA certified which is what Honda recommends.I also ran Rotella 15w40 for a long time in my ST1300. Something like 70 or 80,00 miles. Honda allowed 15w40 in that bike.
But the US standards for on road diesel engine emissions changed in late 2016. Engine manufacturers had to meet much lower emissions and had to install catalytic converters among other changes. Cats are easily clogged by particulates of ash in exhaust gases. Oil mfgs had to change the diesel oil formulations to cut out the previous formulations that contained very high levels of zinc and phosphates that made Rotella such a good oil for engines with tappet valve trains because they create lots of ash. The new formula from 2017 is no longer certified for gas engine use. If a diesel oil is rated API CK-4 it no longer has an additive pack with high zinc & phosphates. It's not the same oil we used in the 2000s and 20teens.
Rotella 15w40 and 5w40 has such a following that the above means nothing to many people and they still run it thinking it's the same oil as before. People like to save money and not read owner's manuals so it doesn't matter to them.
In addition Honda specs API SN or wherever it’s at now, for gasoline engines. Does the T6 have that certification?Rotella T4 &T6 are currently JASO-MA certified which is what Honda recommends.
No it no longer carries SG or higher API certs. Re comment on reading owner's manuals. I should have included oil container labels.In addition Honda specs API SN or wherever it’s at now, for gasoline engines. Does the T6 have that certification?
