Turn signal issue
Rabbit
Ohio
So quick question. Are the turn signals supposed to stay lit as running lamps? It’s one of those things I’ve never paid much attention to until now. I’m sure they are but my left one isn’t and my right one is. I think I damaged my left lamp and need to replace it. Does anyone have an idea what the part number for that assembly might be? Partzilla has 2 different numbers for the same assembly. Thank you.
Modrl year of your motorcycle? Incandescent or LED? Country of residence?
if you have a North American spec NC, the front turn indicators are dual intensity lamps for running lights and turn signals. If it's incandescent, replace the dual filament bulb. If LED, I don't knoww if there are individual parts or if you need to change the whole assembly.
For the non-LED version of the bike, here are the replacement LEDs I used on my 2013 NC700X (to replace the incandescent bulbs):
They are longer than stock, but fit inside the lens perfectly.
@halfSpinDoctor -- did those replacement blink correctly as turn signals? some LED bulbs in an incandescent circuit don't flash correctly. I have a 2015 DCT so should be the same circuit as your 2013.
Country: USA. Bike 2018 NC750x. Pretty sure they’re incandescent. I think I have to change the whole assembly. The turn signal works, but not the running light. I think I broke a wire.
You just need to change the bulb. It uses a dual filament bulb similar to the one in the tail light. The filament for the running light must have burnt out. It happens.
Yep. This happened on my CRF250L when it only had a few thousands miles on it. Running light filament went bad. Just had to pop in a new bulb.
No, they will blink fast unless you also replace the flasher relay, or use load resistors (which I do not recommend).
Here is the flasher relay I have. Works great, but you will lose the 4-way flashers with ignition off feature:
