Well equiped NC
SuperMek
Stockholm, Sweden
Beemerphile
#1 Elite
Danielsville, GA
For $600, Honda can keep them. I bought the Teslas for $170 that are quite bright with a fog shaped beam.
https://www.teslaleds.com/default.aspx
The D2D's are popular for good reason, and if I was of a mind to spend that much, I would also look at Clearwater.
Clearwater Lights High Powered LED Motorcycle Lights
Incredibly well made in the US. They have a collimator lens to direct 80% of the beam to spot and 20% to area lighting (fog). They come with a high/low dimmer so that you can adjust the driving light intensity and get full power with the brights.
pdxer_2000
Portland, OR
What about some US made version instead, but better ones? These are 10W LED with high intensity light output that are very popular, for $360 a pair with cabling:
Well, the problem is there aren't any US manufacturers that make a factory compatible mounts for the existing holes on the light bar. I thought about using some silver Techmount clamp/mounts so I had more options. But honestly, I'm not sure I want something that looks like it's, "Bolted on" when there will hopefully be some non-OEM style mount options that look factory. If Denali or PIAA could come up with something, I would totally be open to getting some.
pdxer_2000
Portland, OR
I just sent SW-MOTECH support department a request to see if they would consider making a bracket for using the Honda OEM light bar. Their HAWK fog lights might work well with the NC. A LED version would be great too. I'll keep folks posted if I hear anything from them.
