lootzyan
The gear shift points given in the manuals are for a very basic, conservative driving style, ensuring the lowest fuel consumption....And what I thought I understood about DCT trans.: "in D mode the trans selects shift points and gets into 6th way too fast and at way too low of rpm, as early as 37 mph. ...
The PCM continuously reads your acceleration or deceleration intentions from throttle position, speed sensor and clock signals and selects gear and shift point accordingly. You can intervene and speed up the PCM responses by manual downshift while still in D mode. Suddenly opening the throttle gives a similar result with a slightly slower response. You choose the method depending on the situation and your preferences. What's cool is no method prevails and you get a sense of comfort from being able to choose.
