Which top box can I get with these bags???
wingnut
Brooklyn
Hi I have these bags and wanted to add a GIVI Monokey. Does anyone know if I can with tis configuration? Or do I have to use the stock Honda box since I have the Honda bags and grab bars?
telecam
Washington DC
Looks like you NC is missing the top rack to attach the factory top case. Givi should have adapters to fit the NC700X so, you should be fine with either box. Givi may end up a bit cheaper.
GregC
Southeast USA
Yep. You’ll need the top rack. Then any givi monolock case will fit with their adapter plate. I’m using a smaller givi E30 to hold a bit of stuff (it will hold my xl sized schuberth c30), and it works fine. You’ll save a good bit compared to the OEM case, even at equivalent size.
