YSS Shock Absorbers
Griff
Wicklow Ireland
Has anyone ever used YSS shock absorbers on their NC's or indeed on any motorcycles ? Any opinions on them ?
Well, all I can offer is that I spoke to a YSS US distributor several times, about 5 years ago, regarding a set of twin rear shocks for an NSS250 Reflex scooter. In the end I passed on the deal because I didn't get a good vib from the seller. He seemed to be just telling me whatever I wanted to hear regarding the potential performance of the shocks. When it came to make a deal he was out of stock of the exact unit I needed, and I would need to compromise a bit, so I dropped the idea altogether. I realize that doesn't tell you anything about the product itself, but that was my experience.
Griff
Wicklow Ireland
Many thanks. Every little helps.
Griff
Wicklow Ireland
They even do one for the NC700X.......
Honda NC700X YSS Shock Absorber (12)
I will probably get one for my CRF250. I will be getting it at a good price and as such I am prepared to take the risk. Given that it could be relevant on here I will do an occasional review to keep y'all informed with regard to quality/performance/longevity etc etc.
Griff
Wicklow Ireland
I am putting this on my 250 today. In the hand it seems a robust item with a fairly easy method of spring preload adjustment and rebound adjustment at the bottom. There is a locknut just under the top eye that allows a 10mm adjustment of the shock length which is also a useful feature. Time will tell as to reliability. I have posted on here because these items are also available for the NC.
Griff
Wicklow Ireland
In most shocks where there is no compression rebound adjustment, the factory seem to build in too much compression damping from the getgo. As such the ride can be harsh until the shock wears, and that can take some time. I was afraid of that possibility with this unit but I was pleasantly surprised to find that there is just the correct amount of compression damping for me. I pushed the little bike hard yesterday over very rough roads that I normally use to test suspension, and some dirt roads. I had several stops to adjust rebound damping and all seemed well with a pleasant change from the OEM shock.
I initially thought that the Spring was a little on the weak side for my weight as I had to put on two full turns of preload to get some decent height to the rear of the bike. The Jury is still out on that aspect but overall I am happy. I may add another turn of preload but not just yet. The shock body was warm but not excessively so after 100kms of bumpy roads. That imho bodes well also. Now I will get on with riding it and hopefully reliability will prove to be good too.
dduelin
North FL USA
If you measure sag with you on the bike and preload set for your weight and then measure sag with the bike unladen the relationship of the two sag numbers can tell you if the spring is OK for your weight. If you can adjust preload to get the laden sag to 25-30% of travel and then have 5-10 mm of unladen sag the spring is good for your weight. If the unladen sag is less than 5 mm the spring is too weak for your weight.
Griff
Wicklow Ireland
Got the sag sorted out now and the shock is working really well. I am posting some photos under the pretext of "testing" the shock. I am saying up front that the quality of my photos is not in the same league as those of Greenboy but one does ones best :)
