2022 Yamaha MT-03 [Specs, Features, Photos]
2022 Yamaha MT-03: The First Step Into the ‘MT’ Family​
Although I discussed Yamaha’s MT-07 having the potential to be one of the best beginner naked motorcycles, if you are intimated by a 689cc mill and are just starting out or lack the funding to secure a pricer model such as the MT-07, the MT-03 is worth checking out.
With virtually no updates to 2022, Yamaha carries the gigantic overhaul that the MT-03 saw last year over to this year. The third generation, Japanese-made MT-03 boasts the same reliable and comfortably powered 321cc parallel-twin engine that allows for 50 horsepower and 24 lb-ft of torque to be unleashed on any surface. The bike’s lightweight nature and overall maneuverability make it perfect for beginners that may be intimidated by some of Yamaha’s larger naked options.
It retains very similar stylings to the rest of the MT family, meaning that despite the massive price discrepancy this bike still looks the part and most importantly performs as expected. Sleek, strong, and the epitome of hyper naked, this diet MT is ready for anything you can throw at it making it the perfect entry model in Yamaha’s 2022 lineup.
The 2022 Yamaha MT-03 starts at $4,799 USD / $5,899 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Yamaha MT-03 in one place.
2022 Yamaha MT-03
  • Price: $4,799 USD / $5,899 CAD
    • Standard ABS
    • LED Lighting
    • LCD instrumentation
Key Specs​
  • Engine Type: 321cc, liquid-cooled DOHC inline 2-cylinder; 8 valves
  • Horsepower: 50 HP
  • Torque: 24 lb-ft
  • Wet Weight: 370 lbs (168 kg)
  • Seat Height: 30.7 inches (780 mm)
Key Competitors​
2022 Yamaha MT-03
2022 Yamaha MT-03 Specifications​
Engine321cc liquid-cooled DOHC 4-stroke; 4 valves
Power50 Hp
Bore x Stroke68.0mm × 44.1mm
Compression Ratio11.2:1
Fuel SystemFuel injection
Lubrication
Clutchwet multiplate clutch
TransmissionConstant mesh 6-speed
Final DriveChain
Suspension Front37mm KYB® inverted fork; 5.1-in travel
Suspension RearSingle shock; 7-step preload adjustable, 4.9-in travel
Brakes FrontHydraulic single disc brake, 298mm; ABS
Brakes RearHydraulic single disc brake, 220mm; ABS
Tires Front110/70R17
Tires Rear140/70R17
Fuel Tank Capacity3.7 gal
Color
Ignition
HeadlightProjector
Overall Length82.3 in
Overall Width29.7 in
Overall Height42.1 in
Wheelbase54.3 in
Ground Clearance6.3 in
Seat Height30.7 in
Wet Weight373 lb
Warranty1 Year (Limited Factory Warranty)
2022 Yamaha MT-03
2022 Yamaha MT-03 Features​
TOP FEATURES​
  • Smooth & Easy To Ride Power Delivery
    This 321cc liquid-cooled two-cylinder engine features lightweight forged pistons and carburized connecting rods, delivering easy to manage power in the low rpm range with strong high rpm power. The extremely light clutch feeling makes the MT-03 even more fun in the city, while its offset cylinders and advanced fuel injection system ensures smooth throttle response.
  • Dual Position Lights with Singular LED Headlight
    The dynamic MT-03 looks cool with its dual angled position lights that emphasize its aggressive big-bike looks. A single compact and powerful LED headlight burns a hole through the darkness to light up the road ahead.
  • Aggressive Next-Gen MT Design
    There’s absolutely no mistaking that the MT-03 is a member of Yamaha’s legendary Hyper Naked family. With its aggressive front light assembly as well as bold air scoops and a sculpted fuel tank, the MT-03 gives you the chance to become a true Master of Torque and experience the most dynamic ride in the class.
  • 37mm KYB® Inverted Front Fork
    The MT-03’s serious big-bike specification is underlined with the addition of an inverted KYB® front fork. Equipped with 37mm tubes and a cast aluminum upper triple clamp, the front end reinforces the bike’s high-specification and delivers a confident and smooth ride during braking, acceleration and cornering.
  • Potent Twin-Cylinder Powerplant
    Yamaha’s 321cc liquid-cooled, inline two-cylinder engine delivers excellent power and performance throughout the rpm range. With a 180-degree crank design and integrated counterbalancer, the layout minimizes vibrations for a smooth, refined engine character.
  • Smooth & Useable Power
    With double overhead cams (DOHC) and four-valve cylinder heads, the MT-03 engine provides easy-to-manage power at low rpms with strong rpm power—ultimately delivering an exciting ride with a broad spread of power.
  • Six-Speed Transmission
    A smooth-shifting six-speed gearbox ensures the rider always has the right ratio, whether riding through tight city streets or on the open highway.
  • Modern Fuel Injection
    Downdraft induction fuel injection system provides easy starting, excellent fuel economy, and responsive performance in all conditions.
  • Advanced Cylinder Construction
    Yamaha’s unique DiASil—a high-silicon aluminum alloy—is used in the cylinders to ensure excellent heat dissipation. An innovative offset cylinder design helps reduce friction and provides better efficiency, quicker response and great overall engine performance.
  • Strong & Lightweight Forged Pistons
    Forged aluminum pistons—the same technology in the MT-10—contributes to reduced power loss and lower vibration levels. This design results in minimized vibrations and smooth running, even at high rpm.
  • Compact Exhaust System
    The short muffler design features modern styling and helps to centralize mass, improving agility for ultra-responsive handling.
CHASSIS/SUSPENSION​
  • Inverted KYB® Front Fork
    The MT-03 features an inverted KYB® fork with optimized spring and damping settings, delivering more solid handling when compared to motorcycles using conventional front forks.
  • Monocross Rear Shock
    The seven-step preload adjustable single-shock design is tuned to strike a balance between ride comfort and sporty performance with capability across a wide range of uses, from urban commuting to extended rides into the twisty canyons.
  • Long Swingarm
    The MT-03 is equipped with a 22.6″ long asymmetrical swingarm that provides a planted ride during braking, cornering and acceleration.
  • Potent Braking with Standard ABS
    The 298mm floating-mount front disc brake ensures excellent stopping power, supported by a 220mm rear disc. The MT-03 ABS model also features an anti-lock braking system to boost rider confidence and prevent wheel lock-ups in reduced-traction conditions.
  • Lightweight Diamond Frame
    The compact diamond-type tubular frame’s combination of low weight and immense strength gives you neutral handling and easy maneuverability in traffic. With its inverted front fork and rear shock with complimenting settings, the MT-03 is ready to carve through the twisties and get your adrenaline flowing!
ADDITIONAL FEATURES​
  • Stylish LED Turn Signals
    Light-Emitting Diode (LED) elements are used for both the front and rear turn signals. Not only do LEDs offer long life with minimal power draw, they provide brilliant illumination for confidence and visibility, during the day or night. The MT-03’s dynamic appearance is reinforced by the LED signals that perfectly complement the bike’s aggressive looks.
  • Dynamic Mass Forward Design
    Yamaha’s Hyper Naked bikes are instantly recognizable thanks to their aggressive and powerful design. A sculpted fuel tank cover is designed to fit snugly with the rider while the lightweight air scoops enhance the look and feel of the mass-forward body design and highlight the dynamic MT family look.
  • Ergonomic Riding Position
    With its compact body and low 30.7″ seat height, the MT-03 is a joy to ride whether you’re escaping traffic or having a blast out on the open road. Behind the aggressive bodywork, a specially sculpted knee area and fuel tank cover work with the high-mounted handlebars to provide an agile and ergonomic riding position.
  • Digital LCD Instrumentation
    To match the MT-03 Hyper Naked’s radical looks, Yamaha has fitted a stylish LCD meter that provides easy-to-absorb information.
2022 Yamaha MT-03 Photos​
2022 Yamaha MT-03 2022 Yamaha MT-03 2022 Yamaha MT-03 2022 Yamaha MT-03
2022 Yamaha MT-03 Videos​
Why The Yamaha MT-03 is the Best Beginner Bike EVER
MT03 vs R3 | Which should you buy?
Yamaha Motorcycles Official Websites​
The post 2022 Yamaha MT-03 [Specs, Features, Photos] appeared first on webBikeWorld.
