2023 Ducati Scrambler 1100 Sport Pro / Dark Pro / Tribute Pro [Specs, Features, Photos]
The 2023 Ducati Scrambler 1100 Pro is A Timeless Classic
Ducati’s 1100 Pro subseries of the Scrambler line has been turning heads for a couple of years now, and while 2023, unfortunately, brings nothing new, the retro-styled roadster remains a beauty to behold and a blast to ride. These Italian modern classics truly aren’t like anything else on the market.
The 2023 Scrambler 1100 series uses an air-cooled 1,079 cc L-Twin that produces an alleged 86 HP and 65 lb-ft of torque. This power is carried to the road through a six-speed transmission and a chain drive. Suspension is courtesy of a Marzocchi fully adjustable front fork and a Kayaba unit in the rear, unless the bike is optioned in the Sport package (more on that later). As this is the Pro model, this bike gets some attractive goodies, including standard a Brembo braking system. The bike also has full LED lighting and a suite of top-of-the-line tech features carried over from elsewhere in Ducati’s 2023 lineup.
The 2023 Ducati Scrambler 1100 Pro can be purchased in three models – the blacked-out & classy “Dark”, the heritage-inspired “Tribute”, and the Top of the line “Sport” model. Each of them share their core fundamentals while still offering something unique.
The Dark and Tribute models are basically the same, only differing in cosmetics. The Dark is, as the name suggests, a blacked-out model featuring black and silver colouring, whereas the Tribute features retro Ducati decals and a unique “Giallo Orca” orange paint job with black accents and a brown leather seat. The Tribute also gets a set of retro wire-spoked wheels over the Dark’s modern ten-spoke style. The Sport model ups the ante a little by adding some premium goodies, like full Ohlins suspension, a drag bar, and bar end mirrors.
The 2023 Ducati Scrambler 1100 Dark Pro starts at $13,895 USD / $16,195 CAD.
The 2023 Ducati Scrambler 1100 Tribute Pro starts at $14,895 USD / $17,595 CAD.
The 2023 Ducati Scrambler 1100 Sport Pro starts at $17,195 USD / $20,195 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc., so you can read up on the new 2023 Ducati Scrambler 1100 Pro in one place.
2023 Ducati Scrambler 1100 Sport Pro / Dark Pro / Tribute Pro2023 Ducati Scrambler 1100 Sport Pro / Dark Pro / Tribute Pro
  • Price: $13,895 USD / $16,195 CAD
    • Brembo Brakes
    • Full Suite of Safety and Performance Electronics
    • Ride By Wire System
    • Full LED lighting
  • Engine: 1,079 cc L-Twin
  • Power: 86 hp
  • Torque: 65 lb-ft
  • Weight: 417 lbs (189 kg)
  • Seat Height: 31.9 inches (810 mm)
  • Triumph Scrambler 1200
  • BMW RnineT Scrambler
2023 Ducati Scrambler 1100 Sport Pro / Dark Pro / Tribute Pro Specifications​
Engine1,079cc L-Twin, Desmodromic distribution, 2 valves per cylinder, air cooled
Power86 hp (63 kW) 7,500 rpm/min
Bore x Stroke98 x 71 mm
Compression Ratio11:1
Fuel SystemElectronic fuel injection, Ø55 mm throttle body with full Ride by Wire (RbW)
Exhaust2-1-2 system with catalytic converter and 2 lambda probes, twin stainless steel muffler with aluminium covers and end caps
ClutchLight action, wet, multiplate clutch with hydraulic control. Self-servo action on drive, slipper action on over-run
Transmission6 speed
Final DriveChain; Front sprocket 15; Rear sprocket 39
Suspension FrontMarzocchi fully adjustable Ø45 mm usd fork
Suspension RearKayaba monoshock, pre-load and rebound adjustable
Brakes Front2 x Ø320 mm semi-floating discs, radially mounted Brembo Monobloc M4.32 callipers, 4-piston, axial pump with Bosch Cornering ABS as standard equipment
Brakes RearØ245 mm disc, 1-piston floating calliper with Bosch Cornering ABS as standard equipment
Tires Front
Tires Rear
Fuel Tank Capacity15 l – 3.96 US gal
ColorViper Black
Ignition
HeadlightLED
Max Length2,190 mm (86.0 in)
Max Width895 mm (35.2 in)
Max height1,330 mm (52.4 in)
Wheelbase1,514 mm (59.6 in)
Trail111 mm (4,4 in)
Seat Height810 mm (31,9 pol.)
Dry Weight189 kg (417 lb)
Warranty24 months unlimited mileage
2023 Ducati Scrambler 1100 Sport Pro / Dark Pro / Tribute Pro Features​
Riding comfort​
With tubular steel trellis frame with double top beam. Essential, like the Scrambler, it embraces the engine and is completed by an aluminium rear frame. It guarantees great agility in traffic as much as between hairpin bends in the mountains. Thanks to the wide handlebar, moving between urban obstacles is child’s play with the Scrambler, while the 1,514 mm wheelbase maximises stability, even at high speeds.
Brembo braking system​
The Scrambler 1100 Dark PRO is equipped with a Brembo braking system with ABS Cornering, which guarantees safety in all types of corners. At the front, a 320 mm diameter double disc has been fitted to two Brembo M 4.32B monobloc four-piston calipers with radial connection. At the rear there is a 245 mm disc on which a 34 mm single-piston caliper works. The ABS system has only one level of intervention and is not switchable.
Innovative lighting​
The light guide along the outer circumference, powered by an LED source that acts as a position light, is a DRL (Daytime Running Light), which allows the Scrambler 1100 Dark PRO to be easily recognizable even during the day. Taking inspiration from the tape that was applied to the headlights in the 1970s to preserve the light cluster, a black metal “X” was recreated inside the headlight. At the rear, the optical group is of the full LED type with a diffusion effect and uses a technology that is unique in the world of two wheels.
2023 Ducati Scrambler 1100 Sport Pro / Dark Pro / Tribute Pro Photos​
2023 Ducati Scrambler 1100 Sport Pro / Dark Pro / Tribute Pro 2023 Ducati Scrambler 1100 Sport Pro / Dark Pro / Tribute Pro 2023 Ducati Scrambler 1100 Sport Pro / Dark Pro / Tribute Pro 2023 Ducati Scrambler 1100 Sport Pro / Dark Pro / Tribute Pro
2023 Ducati Scrambler 1100 Sport Pro / Dark Pro / Tribute Pro Videos​
All-New 2023 Ducati Scrambler 1100 Tribute Pro & Ducati Scrambler 1100 Sport Pro New Look More Manly by Auto Car:
Ducati Scrambler 1100 vs 800: Which Should You Buy? by MOTOBOB:
The post 2023 Ducati Scrambler 1100 Sport Pro / Dark Pro / Tribute Pro [Specs, Features, Photos] appeared first on webBikeWorld.
