2023 Honda Grom [Specs, Features, Photos]
The 2023 Honda Grom: Do You Even Grom Bro?
I love that Japanese builders are willing to be daring and build such epic and fun machines like the Grom. In the 2023 Honda Lineup, the Grom is a huge part of the Mini-moto segment.
The Grom went through a refresh last year. The 123.9 cc air-cooled, single-cylinder engine produces a modest 9.7 horsepower and 7.7 lb-ft of torque. It’s a revision from the last version, with a smaller displacement, a smaller bore, and a longer stroke, but a higher power output. Honda also gave the Grom a 5th gear, for those top-speed runs you are certain to attempt.
Anti-Lock Brakes (ABS) are still an option for the 2023 model, and Honda has given us 3 new colorways for the standard version and 1 colorway for the ABS model.
The 2023 Honda Grom starts at $ 3,499 USD / $ 4,614 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Honda Grom in one place.
2023 Honda Grom2023 Honda Grom
  • Price: $ 3,499 USD / $ 4,614 CAD
      • 125 cc fuel-injected engine
      • All-new bodywork
      • Inverted fork suspension
  • Colors:
    • Standard: Matte Black Metallic, Cherry Red, Force Metallic Silver
    • ABS: Pearl White
Main Specs​
  • Engine: 123.9 cc air-cooled four-stroke 80º single-cylinder
  • Power: 9.7 HP
  • Torque: 7.7 lb-ft
  • Curb Weight: 227 lbs (103 kg)
  • Seat Height: 29.9 in (760 mm)
Competitors​
  • Kawasaki Z125 Pro
  • Honda Monkey
  • Benelli TNT 135
2023 Honda Grom Specifications​
Engine124cc air-cooled single-cylinder four-stroke
Power9.7 HP
Bore x Stroke50mm x 63.1mm
Compression Ratio10:1
InductionPGM-FI with automatic enrichment
Valve TrainSOHC; two valves per cylinder
Clutch
TransmissionFive-speed
Final Drive15T/38T; Chain
Suspension Front31mm telescopic inverted fork; 3.9 inches of travel
Suspension RearSingle shock with steel box-section swingarm; 4.1 inches of travel
Brakes FrontSingle 220mm disc with hydraulic dual-piston caliper
Brakes RearSingle 190mm disc with hydraulic single piston caliper
Tires Front120/70-12
Tires Rear130/70-12
Fuel Tank Capacity1.6 gallons
ColorMatte Black Metallic, Cherry Red, Force Metallic Silver
IgnitionDigital transistorized with electronic advance
Headlight
Tail Light
Overall Length
Ground Clearance
Trail4.0 inches
Wheelbase47.2 inches
Rake (Caster Angle)25°
Seat Height30 inches
Curb Weight223 pounds (Includes all standard equipment, required fluids and full tank of fuel—ready to ride)
2023 Honda Grom Features​
PERFORMANCE​
124cc FUEL-INJECTED ENGINE
Nobody can match our reputation for engines, and even though the Grom may be compact, it’s a giant in terms of performance and reliability.
COMFORT​
LOW SEAT HEIGHT
At just 30 inches the Grom makes it easy to flat-foot it in parking lots or at stop lights. Plus, the seat features thick padding so it’s comfortable, especially for taller riders.
ENGINEERING​
HYDRAULIC DISC BRAKES
The Grom features 220mm front and 190mm rear single disc brakes for excellent stopping power.
STYLE​
UNIQUE BODYWORK
Part of the fun of owning and riding a Grom is the way it looks. Plus, its unique bodywork is easy to remove if you want to customize it even further. In addition, the engine, exhaust, wheels and swingarm are all blacked out for an edgy look.
LED HEADLIGHT
The Grom’s LED projector-style headlight not only looks great and is a major styling element, but it also provides excellent illumination.
FIVE-SPEED TRANSMISSION
The Grom features a five-speed transmission. You still get all the durability, control and efficiency of a conventional motorcycle, but the five gears help increase top speed for highway cruising.
LED TAILLIGHT
Forget about big, bulky taillights—the Grom’s LED lamp is bright and clear.
MULTI-FUNCTION DIGITAL INSTRUMENT DISPLAY
The instrument display features speedometer, odometer, tachometer, gear position indicator, A&B trip meters, fuel gauge, clock, and indicator for low/high beam.
OPTIONAL ABS
Our Honda Anti-Lock Braking System (ABS) is available on the Grom, which helps you make confident stops under less-than-ideal conditions.
CONVENIENCE​
FUEL CAPACITY
Who says being on a budget can’t be fun? With its 1.6-gallon fuel tank you can venture far and economically too.
TWO-UP CAPABILITY
Want to share the fun with a friend? No problem—the Grom makes it easy to bring a passenger along.
2023 Honda Grom Photos​
2023 Honda Grom 2023 Honda Grom 2023 Honda Grom 2023 Honda Grom
2023 Honda Grom Videos​
ALL-NEW 2023 HONDA GROM: First 24 Hour Impression!!!
2023 Honda Grom ABS Review / Small bike that is BIG on fun!
Honda Websites​
Other Links​
The post 2023 Honda Grom [Specs, Features, Photos] appeared first on webBikeWorld.
