2023 Honda Shadow Aero [Specs, Features, Photos]
The 2023 Honda Shadow Aero: Classic & Understated
The Honda Shadow is one of the Japanese builders longest running models and a bike that holds a soft spot for many. The Shadow Aero returns to the Honda USA 2023 lineup virtually unchanged from last year, sadly those in Canada will not have access to the Shadow family of Cruisers.
The Shadow is powered by a liquid-cooled, 745cc V-twin engine that produces 45 horsepower and 47 lb-ft of torque. The engine is mated to a five-speed transmission and delivers smooth and predictable power delivery. The Honda Shadow Aero has a low seat height of 25.9 inches, making it accessible to a wide range of riders.
The Aero is all about the classic cruiser bike styling with two-tone paint, sweeping fenders, spoked wheels, and tank-mounted gauges. The riding position is all about comfort, and the Honda Shadow Aero will make the perfect companion for plenty of weekend miles.
The 2023 Honda Shadow Aero starts at $7,799 USD / $ N/A CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Honda Shadow Aero in one place.
2023 Honda Shadow Aero2023 Honda Shadow Aero
  • Price: $7,799 USD / $ N/A CAD
      • V-Twin Engine
      • Tank-Mounted Instruments
      • Shaft Final Drive
      • Low Seat Height
  • Colors: Ultra Blue Metallic
Main Specs​
  • Engine: 745cc liquid-cooled 52° V-twin
  • Power: 44.6 horsepower
  • Torque: 47.9 lb/ft
  • Wet Weight: 560 lbs (254 kg)
  • Seat Height: 25.9 In (658 mm)
Competitors​
  • Suzuki Boulevard C50
  • Indian Scout Bobber Sixty
  • Harley Davidson Softail Standard
2023 Honda Shadow Aero Specifications​
Engine745cc liquid-cooled 52-degree V-twin four-stroke
Power44.6 Hp
Bore x Stroke79mm x 76mm
Compression Ratio9.6:1
InductionProgrammed Fuel Injection (PGM-FI); 34mm throttle body
Starter
Valve TrainSOHC; three valves per cylinder
Clutch
TransmissionWide-ratio five-speed
Final DriveShaft
Suspension Front41mm fork; 5.5-inch travel
Suspension RearDual shocks with five-position spring-preload adjustability; 3.6-inch travel
Brakes FrontSingle 296mm disc with twin-piston caliper
Brakes RearSingle 276mm disc
Tires Front120/90-17
Tires Rear160/80-15
Fuel Tank Capacity3.7 gallons, including 0.9-gallon reserve
ColorUltra Blue Metallic
IgnitionDigital transistorized with electronic advance
Headlight
Tail Light
Overall Length
Ground Clearance
Trail161mm (6.3 inches)
Wheelbase64.5 inches
Rake (Caster Angle)34°
Seat Height26.0 inches
Curb Weight560 pounds (Includes all standard equipment, required fluids and a full tank of fuel)
2023 Honda Shadow Aero Features​
PERFORMANCE​
V-TWIN ENGINE​
Nothing pumps out the torque like a big V-twin. The Aero’s power makes it perfect for around-town cruising, commutes and casual weekend-long rides.
PROGRAMMED FUEL INJECTION (PGM-FI)​
Forget about fiddling with a choke—the Shadow’s fuel injection system means no-hassle startups on cold mornings or at high altitudes, and optimal performance in any condition.
THREE-VALVE DUAL-PLUG COMBUSTION CHAMBER​
It’s the best of both worlds: The three-valve combustion chambers used on many of our V-twin cruisers feature two intake valves and one exhaust, helping them breathe efficiently to boost both horsepower and torque.
STYLE​
2-INTO-2 EXHAUST SYSTEM​
Sleek pipes feature bullet-style mufflers for that classic cruiser style of yesteryear. Large-diameter head pipes and the 2-into-2 system design combine to put out true, V-twin cruiser sound.
TANK-MOUNTED INSTRUMENTS​
A key element of the Shadow Aero’s look are the tank-mounted instruments. Set in a gorgeous chromed pod and complemented by the chromed fuel-filler cap, they really set off the bike’s classic lines.
BLACKED-OUT STYLING​
The closer you look at a Shadow Aero, the better it looks. That’s because the styling is so unified. Check out the way the blacked-out engine, rims, and frame all work together visually.
CHROME HIGHLIGHTS​
Chrome highlights include cylinder-head covers, air-cleaner cover, engine sidecovers, brake and clutch-lever brackets, rear brake pedal, shift lever, handlebar, rear shock covers and more.
FULL FRONT FENDER​
A wide metal front fender gives the Aero a classic styling touch.
SPOKED WHEELS​
Spoked wheels give the Aero a classic look.
COMFORT​
COMFORTABLE SADDLE​
Broad, low-slung solo seat features a detachable passenger seat.
LOW SEAT HEIGHT​
The Aero’s low seat height makes flat-footing it at stoplights or in parking lots a breeze. And the Aero’s narrow seat/tank junction makes it feel even lower.
FIVE-SPEED TRANSMISSION​
Wide-ratio five-speed transmission lets you cruise the boulevard at a low, unhurried pace, yet allows you to hop on the highway without revving the engine through the roof.
SHAFT FINAL DRIVE​
Clean, efficient, proven, and low maintenance. Shaft final drive is the perfect choice for a machine like this, and for riders who pile on the miles. You never have to worry about lubrication or adjustment out on the road. And an added plus: it helps keep your bike cleaner, too.
2023 Honda Shadow Aero Photos​
2023 Honda Shadow Aero 2023 Honda Shadow Aero 2023 Honda Shadow Aero 2023 Honda Shadow Aero
2023 Honda Shadow Aero Videos​
New Honda Shadow 750 Accessory Guide: Windshield, Exhaust, Highway / Crash Bars | VT750 Motorcycle
Honda Websites​
Other Links​
The post 2023 Honda Shadow Aero [Specs, Features, Photos] appeared first on webBikeWorld.
