2023 Husqvarna Vitpilen 401 [Specs, Features, Photos]
The 2023 Husqvarna Vitpilen 401: Edgy Urban Thrills
The Vitpilen 401 from the Swedish brand Husqvarna, is aimed at riders who appreciate a combination of style, performance, and agility.
While it does share many similarities with its Svartpilen 401 sibling from the 2023 Husqvarna lineup, the Vitpilen 401 has a more café racer-inspired aesthetic. The bodywork is sleek and compact in appearance, featuring a narrow fuel tank, a slim tail section, and a streamlined front end. Clip-on handlebars are connected to forged aluminum triple-clamps plus the rear-set footpegs place the rider in a comfortable and engaged position. The ergonomics prioritize maneuverability and control, making it well-suited for quick cornering and nimble handling.
The engine makes a solid 44 horsepower and is mated to a slick 6-speed gearbox that allows clutchless up and downshifts. Braking comes via ByBre brake calipers with 320mm front and 230mm rear discs with the latest Bosche ABS technology. WP Suspension provides the 43mm front forks and progressively damp rear mono shock.
Husqvarna has created a stunningly nimble urban warrior. There is simply nothing else available this unique and fun to ride.
The 2023 Husqvarna Vitpilen 401 starts at $5,649 USD / $6,599 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Husqvarna Vitpilen 401 in one place.
2023 Husqvarna Vitpilen 4012023 Husqvarna Vitpilen 401
  • Price: $5,649 USD / $6,599 CAD
    • 44 hp 373 cc single-cylinder engine
    • ByBre brake calipers & Two-channel Bosch ABS
    • WP suspensions
  • Easy Shift
  • Engine: 373 cc, single-cylinder, 4-stroke, liquid cooled, SOHC
  • Power: 44 hp (32 kW) at 9,000 rpm
  • Torque: 27 lb-ft (37 Nm) at 7,000 rpm
  • Wet Weight: 333 lbs (151 kg)
  • Seat Height: 32.9 in. (835 mm)
2023 Husqvarna Vitpilen 401 Specifications​
Engine​
Transmission6-speed
CoolingLiquid cooled
Power in KW32 kW
StarterElectric starter
Bore and Stroke89 mm x 60 mm
ClutchPASC
antihopping clutch, mechanically operated
CO2 emissions77 g/km
Displacement373 cm³
EMSBosch EMS
Design1-cylinder, 4-stroke engine
Fuel consumption
Chassis​
Weight (without fuel)151 kg
Tank capacity (approx.)9.5 l
ABStwo channel Bosch 10.1MB
Front brake disc diameter320 mm
Rear brake disc diameter230 mm
Front brakeFour-piston radial fixed calliper
Rear brakeSingle-piston floating calliper
ChainX-Ring 5/8 x 1/4″
Frame designChrome-moly tubular space frame, powder-coated
Front suspensionWP APEX 43
Ground clearance145 mm
Rear suspensionWP APEX – Monoshock
Seat height835 mm
Steering head angle65 °
Suspension travel (front) 142 mm
Suspension travel (rear)150 mm
2023 Husqvarna Vitpilen 401 Features​
Engine​
The Vitpilen 401 is powered by a modern 373cc single-cylinder engine that is remarkably compact. With 37Nm of torque from low down in the RPM range and a 6-speed gearbox, it is perfect for urban riding. The electronic fuel injection is operated by a ride-by-wire system and delivers a controlled and refined power. With a peak horsepower of 32 kW (44 hp), the VITPILEN 401 is accessible to a wide variety of riders, while its lightweight construction means the power-to-weight ratio will also excite more experienced riders. For added convenience, the gearbox is linked to an Easy Shift sensor which allows the rider to make seamless up and down shifts without the use of the clutch. The sensor works by relaying the moment the rider actuates the gear lever to the ECU which in turn matches engine parameters to allow a simple gear change at any RPM or engine load.
Frame​
The trellis frame is central to the Vitpilen 401 character and agility. Made from high strength chromium molybdenum steel using hydro formed tubes and robot welding, the frame is not only strong but also lightweight ensuring nimble handling and detailed feedback to the rider. Designed with specific flex characteristics, the frame works in harmony with the WP suspension to offer a comfortable and confident feel combined with a tight turning circle for ease of use in urban environments. The optimized subframe is extended by 40 mm for improved comfort when accompanied by a pillion rider.
Brakes​
The Vitpilen 401 is fitted with hydraulic ByBre brake callipers, which are manufactured to the highest standards, and in combination with 320mm front and 230mm rear perforated steel discs, deliver controllable and confident braking performance.The Vitpilen 401 is also fitted with a state-of-the-art Bosch ABS system, ensuring the highest level of safety in varying braking conditions.
Suspension​
The WP suspension on the Vitpilen 401 is made to exacting standards, ensuring the highest level of quality and craftsmanship. The front suspension features 43 mm open cartridge forks, while the rear features a progressive damping system connected directly to the swingarm. The high-quality components offer dynamic handling optimal for challenging urban environments.
Exterior​
Reduced to an authentic mix of classic thinking and modern design. This Vitpilen 401 is synonymous with the Swedish heritage of Husqvarna Motorcycles. The lightweight and narrow bodywork is shaped into the Vitpilen 401´s progressive design and intelligently allows for seamless movement while riding.
Wheels​
The 17″ anodised spoked wheels are a design highlight of the Vitpilen 401. The wheels offer a unique sense of style and are also very robust, offering premium reliability on unpredictable and challenging urban terrain.
Controlzone and triple clamp​
Clip-on handlebars attach to forged aluminium triple clamps, a central focal point to the Vitpilen 401. In keeping with the minimalistic look and authentic design, the control zone is not obstructed by any fairings and features a digital display unit with the necessary information.
Lights​
The front and rear lights are distinct elements on the Vitpilen 401 and use the latest LED technology, the lights are more than just designer pieces and offer advanced lighting performance and visibility in urban environments.
Seat​
The seat of the Vitpilen 401 uses high-quality foam and leather fabric, which, despite its reduced appearance, remains comfortable for the rider. Extending from the main bodywork and seamlessly floating above the rear wheel, the seat adds to the unique riding experience that the Vitpilen 401 provides.
2023 Husqvarna Vitpilen 401 Photos​
2023 Husqvarna Vitpilen 401 2023 Husqvarna Vitpilen 401 2023 Husqvarna Vitpilen 401 2023 Husqvarna Vitpilen 401
2023 Husqvarna Vitpilen 401 Videos​
Why beginner riders should buy a Vitpilen/Svartpilen 401.
Vitpilen 401 Has A Unique Retro-Modern Feel | 2023 Husqvarna Vitpilen 401
Husqvarna Motorcycles Websites​
Other Links​
The post 2023 Husqvarna Vitpilen 401 [Specs, Features, Photos] appeared first on webBikeWorld.
