2023 Kawasaki Ninja 1000SX [Specs, Features, Photos]
The 2023 Kawasaki Ninja 1000SX Is A Capable And Powerful Sport Touring Motorcycle
Kawasaki’s 2023 Ninja 1000 SX stands out as a compelling choice in the sport touring segment, blending performance, comfort, and advanced technology. This bike has a powerful 1,043cc inline-four engine, which delivers a thrilling 140 horsepower along with a well-rounded riding experience. The engine is paired with a 6-speed transmission featuring a quick shifter, allowing for clutchless upshifts and seamless acceleration. Aiding rider control, the motorcycle also comes equipped with an Assist and Slipper Clutch and electronic cruise control.
Showcasing an aggressive design, the Ninja 1000 takes its styling cues from its more potent siblings in the Kawasaki lineup. The motorcycle features a distinctive LED headlight and taillight, contributing to its modern and sleek appearance. The bike is not short on the tech side and is well equipped with a full-color TFT display, providing riders with essential information and smartphone connectivity through Kawasaki’s smart phone integration.
Reigning in the power and keeping things in line In the suspension department, the Ninja 1000 features a fully adjustable 41mm inverted fork in the front and a horizontal back-link shock with adjustable rebound damping and preload in the rear. Braking capabilities are provided by high-quality components, including dual 300mm front discs with radial-mount monobloc calipers and a single 250mm rear disc, all supported by advanced technology. All this just means that you get an excellent performing motorcycle that is at the top of the sport touring realm and compares well with other Japanese brands in this segment.
The 2023 Kawasaki Ninja 1000 SX starts at: $13,199 USD/$15,699 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Kawasaki Ninja 1000 SX in one place.
2023 Kawasaki Ninja 1000SX2023 Kawasaki Ninja 1000SX
  • Price: $13,199 USD/$15,699 CAD
    • Assist & Slipper Clutch
    • Riding Modes
    • Cruise Control
    • TFT display
  • Engine: 1,043 cc 4-stroke, In-Line Four, DOHC, 16-valve, liquid-cooled
  • Power: 140 horsepower
  • Torque: 82 lb-ft
  • Weight: 513 lbs (232 kgs)
  • Seat Height: 32.3 inches (820 mm)
2023 Kawasaki Ninja 1000SX Specifications​
Engine1,043cc, liquid-cooled, 4-stroke, DOHC 16-valve in-line four
Power140 hp
Bore x Stroke77.0 x 56.0mm
Compression Ratio
11.8:1
Fuel SystemFuel injection: ø38 mm x 4
LubricationForced lubrication, wet sump
ClutchWet multi-disc, manual
Transmission6-speed, Return
Final DriveChain
Suspension Frontø41 mm inverted fork with compression and rebound damping and spring preload adjustability / 120 mm (4.7 in)
Suspension RearHorizontal Back-link, gas-charged shock with rebound damping and remote spring preload adjustability / 144 mm (5.7 in)
Brakes FrontDual semi-floating ø300 mm discs with radial-mount, monobloc, opposed 4-piston calipers
Brakes Rear
ø250 mm disc with single-piston caliper
Tires Front120/70ZR17M/C (58W)
Tires Rear190/50ZR17M/C (73W)
Fuel Tank Capacity19 litres
Color
Emerald Blazed Green / Metallic Diablo Black / Metallic Graphite Gray /Metallic Matte Sovereign Red / Metallic Diablo Black /Metallic Matte Carbon Gray
IgnitionDigital
HeadlightLED
Overall Length82.7 in
Overall Width32.5 in
Overall Height46.9 / 48.2 in
Wheelbase1,440 mm (56.7 in)
Ground Clearance5.3 in
Seat Height32.3 in
Curb Weight514 lb
Warranty12 Months
Kawasaki Protection Plus12 / 24 / 36 / 48 months
2023 Kawasaki Ninja 1000SX Features​
Assist & Slipper Clutch​
Economical Riding Indicator​
Electronic Cruise Control​
Electronic Cruise Control allows a desired speed (engine rpm) to be maintained with the simple press of a button. Once activated, the rider does not have to constantly apply the throttle. This reduces stress on the right hand when traveling long distances, enabling relaxed cruising and contributing to a high level of riding comfort.
Electronic Throttle Valves​
Kawasaki’s fully electronic throttle actuation system enables the ECU to control the volume of both the fuel (via fuel injectors) and the air (via throttle valves) delivered to the engine. Ideal fuel injection and throttle valve position results in smooth, natural engine response and the ideal engine output. The system also makes a significant contribution to reduced emissions.
Electronic throttle valves also enable more precise control of electronic engine management systems like S-KTRC and KTRC, and allow the implementation of electronic systems like KLCM, Kawasaki Engine Brake Control, and Electronic Cruise Control.
KCMF (Kawasaki Cornering Management Function)​
Using the latest evolution of Kawasaki’s advanced modeling software and feedback from a compact IMU (Inertial Measurement Unit) that gives an even clearer real-time picture of chassis orientation, KCMF monitors engine and chassis parameters throughout the corner – from entry, through the apex, to corner exit – modulating brake force and engine power to facilitate smooth transition from acceleration to braking and back again, and to assist riders in tracing their intended line through the corner. The systems that KCMF oversees vary by model, but may include:
KQS (Kawasaki Quick Shifter)​
Designed to help riders maximize their acceleration on the track by enabling clutchless upshifts with the throttle fully open, KQS detects that the shift lever has been actuated and sends a signal to the ECU to cut ignition so that the next gear can be engaged without having to use the clutch. On models that offer clutchless downshifts, during deceleration the system automatically controls engine speed so that the next lower gear can be selected without operating the clutch.
Power Modes​
Models equipped with multiple Power Modes offer riders an easily selectable choice of engine power delivery to suit riding conditions or preference. In addition to Full Power mode, one (Low) or two (Middle, Low) alternate mode(s) in which maximum power is limited and throttle response is milder are provided.
Smartphone Connectivity​
Clever technology enables riders to connect to their motorcycle wirelessly. Using the smartphone application “RIDEOLOGY THE APP,” a number of instrument functions can be accessed, contributing to an enhanced motorcycling experience. Vehicle information (such as the odometer, fuel gauge, maintenance schedule, etc) can be viewed on the smartphone. Riding logs (varies by model, but may include GPS route, gear position, rpm, and other information) can be viewed on the smartphone. When connected, telephone (call, mail) notices are displayed on the instrument panel. Riders can also make changes to their motorcycle’s instrument display settings (preferred units, clock and date setting, etc) via the smartphone. And on certain models, it is even possible to check and adjust vehicle settings (such as Rider Mode, electronic rider support features, and payload settings) using the smartphone.
2023 Kawasaki Ninja 1000SX Photos​
2023 Kawasaki Ninja 1000SX 2023 Kawasaki Ninja 1000SX 2023 Kawasaki Ninja 1000SX 2023 Kawasaki Ninja 1000SX
2023 Kawasaki Ninja 1000SX Videos​
2023 Kawasaki Ninja 1000SX review by Motorevs27:
2023 Kawasaki Ninja 1000SX Review by Old Guy Ridin’:
Kawasaki Official Websites​
The post 2023 Kawasaki Ninja 1000SX [Specs, Features, Photos] appeared first on webBikeWorld.
