2023 Kawasaki Vulcan 1700 Vaquero ABS [Specs, Features, Photos]
The 2023 Kawasaki Vulcan 1700 Vaquero ABS: A Top-of-the-Line Bagger Cruiser Motorcycle
The 2023 Kawasaki Vulcan 1700 Vaquero ABS is one of 4 Vulcans in Kawasaki’s 2023 lineup and is a top-of-the-line bagger cruiser motorcycle that packs a powerful punch with its large 1,700cc V-twin engine. With a stylish and sleek design, the Vulcan 1700 Vaquero ABS offers a smooth and comfortable ride, perfect for long-distance cruising. One of the key features that Kawasaki motorcycles are known for is their technology which includes Kawasaki’s Intelligent Anti-Lock Brake System (ABS) that helps prevent wheel lock-up and provides excellent stopping power. The Vulcan 1700 Vaquero ABS also comes with Kawasaki’s K-ACT II which links the front and rear brakes for more precise stopping power.
Another impressive aspect of the Vaquero is its comfortable and spacious seating arrangements. The rider and passenger seats are both generously padded and offer plenty of room for long-distance cruising. The bike also comes with a range of standard features, such as a tall windshield, cruise control, and a premium sound system.
In terms of handling and maneuverability, the Vulcan 1700 Vaquero ABS is surprisingly agile for a bagger cruiser. Its long wheelbase and low center of gravity make it easy to handle and navigate through tight turns and corners. The bike also features adjustable rear air suspension, allowing riders to customize the ride to their liking. As a premier Japanese motorcycle manufacturer, Kawasaki has set the bar extremely high for this segment of motorcycles.
The 2023 Kawasaki Vulcan 1700 Vaquero ABS starts at $18,599 USD/$21,399 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Kawasaki Vulcan 1700 Vaquero ABS in one place.
2023 Kawasaki Vulcan 1700 Vaquero ABS2023 Kawasaki Vulcan 1700 Vaquero ABS
  • Price: $18,599 USD/$21,399 CAD
    • Fuel-Injected 1,700 cc V-Twin
    • Cruise Control
    • ABS
    • Sealed Saddlebags
  • Engine: 1,700cc, liquid-cooled, 4-stroke, SOHC 8-valve V-twin
  • Power: 81 horsepower
  • Torque: 107.6 lb-ft
  • Weight: 844 lbs (383 kgs)
  • Seat Height: 28.7 inches (730 mm)
2023 Kawasaki Vulcan 1700 Vaquero ABS Specifications​
Engine1700cc, 4-stroke, 52-degree V-twin, liquid-cooled
Power81Hp
Bore x Stroke102.0 x 104.0mm
Compression Ratio
9.5:1
Fuel SystemDFI 42mm Throttle Bodies (2)
Lubrication
Clutch
Transmission6-speed with overdrive and positive neutral finder
Final DriveCarbon fiber-reinforced belt
Suspension Front45mm Showa telescopic fork/5.5 in
Suspension RearSwingarm with twin air-assisted shocks, with 4-way rebound damping/3.1 in
Brakes FrontDual 300mm discs, dual four-piston calipers, K-ACT II ABS
Brakes Rear
Single 300mm disc, twin-piston caliper, K-ACT II ABS
Tires Front130/90-16
Tires Rear170/70-16
Fuel Tank Capacity5.3 gal
Color
Metallic Matte Graphenesteel Gray
IgnitionTCBI w/ Electronic Advance
HeadlightLED
Overall Length98.8 in
Overall Width38.2 in
Overall Height50.8 in
Wheelbase65.6 in
Ground Clearance5.7 in
Seat Height28.7 in
Curb Weight844.5 lb*
Warranty36 Month Limited Warranty
Kawasaki Protection Plus12, 24, 36 months
2023 Kawasaki Vulcan 1700 Vaquero ABS Features​
Electronic Cruise Control​
Electronic Cruise Control allows a desired speed (engine rpm) to be maintained with the simple press of a button. Once activated, the rider does not have to constantly apply the throttle. This reduces stress on the right hand when traveling long distances, enabling relaxed cruising and contributing to a high level of riding comfort.
Dual Throttle Valves​
ABS (Anti-lock Brake System)​
K-ACT (Kawasaki Advanced Coactive-braking Technology) ABS​
At its heart, K-ACT ABS is an advanced anti-lock braking system, designed to keep tires from locking up during braking. But K-ACT ABS was designed to be used on touring models weighing in excess of 300 kg (661 lb) – and that is before adding a passenger and luggage.
Complementing its standard ABS function, K-ACT ABS links the front and rear brakes. It monitors the brake force the rider is exerting at both the front and rear, and takes into consideration vehicle speed to ensure highly effective braking while maintaining chassis stability.
For example, let’s say the rider pulls on the front brake lever. To keep the bike from pitching forward, the ABS ECU actuates the rear brake (via fluid pumps) to ensure that front-rear balance is maintained. Should the rider push the rear brake pedal, the system actuates the front brake as well to distribute the load more evenly so that the rear wheel does not lock up. Based on the vehicle speed, K-ACT decides the optimum hydraulic pressure to send to each caliper, ensuring that even with a heavy motorcycle, stable braking performance is possible.
2023 Kawasaki Vulcan 1700 Vaquero ABS Photos​
2023 Kawasaki Vulcan 1700 Vaquero ABS 2023 Kawasaki Vulcan 1700 Vaquero ABS 2023 Kawasaki Vulcan 1700 Vaquero ABS 2023 Kawasaki Vulcan 1700 Vaquero ABS
2023 Kawasaki Vulcan 1700 Vaquero ABS Videos​
2023 Kawasaki Vulcan 1700 Vaquero ABS review by Peter Lowe One:
2023 Kawasaki Vulcan 1700 Vaquero ABS Review by Auto Car:
Kawasaki Official Websites​
The post 2023 Kawasaki Vulcan 1700 Vaquero ABS [Specs, Features, Photos] appeared first on webBikeWorld.
