2023 Suzuki GSX-S1000GT/GT+ [Specs, Features, Photos]
The 2023 Suzuki GSX-S1000GT Is A Sport Touring Powerhouse
In 2022 Rider Magazine named this bike its Motorcycle of the year, and we couldn’t agree with that choice more. The Suzuki GSX-S1000GT is an excellent sport tourer that ticks so many boxes – superbike performance? Check. Comfortable? Check. State-of-the-art tech? Check. The list goes on.
The 2023 Suzuki GSX-S1000GT is a brilliantly designed sport-touring bike based on the equally brilliant GSX-S1000, which is, in turn, based on the amazing GSX-R1000. Carried over from its siblings in the 2023 Suzuki lineup, the S1000GT houses a 999cc inline 4 powerplant that produces 150 hp and 79.6 lb-ft of torque. Suzuki’s design team says the engine has been retuned specifically for this bike in order to create a more usable midrange for touring purposes.
The GSX-S1000GT has been engineered specifically for a comfortable ride – the bike features vibration-damping handlebars & footpegs, a specially designed seat covered in a new material which promotes grip, and an aerodynamics package which reduces as much wind as possible for a comfortable ride while still maintaining performance. Additionally, the Japanese-made motorcycle comes standard with fully adjustable inverted front forks and a link-style rear suspension setup. Finally, the GT has custom-made Dunlop SPORTMAX Roadsport 2 tires which were created with the sole purpose of keeping this bike agile and comfortable.
The Suzuki GSX-S1000GT has a pretty intense electronics package called the Suzuki Intelligent Ride System (S.I.R.S.). This system equips the bike with features such as a drive mode selector, an intelligent traction control system, and low-RPM assist, just to name a few. All of those features and more can be monitored and controlled from the bike’s 6.5-inch full-colour display. Naturally, as a tourer, the GT also comes with a cruise control system, which Suzuki claims is capable of maintaining speeds up to 110mph (180 km/h).
The GT is available in two variations – the basic package and the GT+ package, which adds on a set of paint-matched 25.7-litre saddlebags. In the United States the basic GT package is only available in Metallic Reflective Blue, while the GT+ can be purchased in Metallic Triton Blue or Glass Sparkle Black. In Canada both packages can be purchased in all three colours.
The 2023 Suzuki GSX-S1000GT starts at $13,349 USD / $16,099 CAD. The GT+ Package is an additional $750 USD/ $1,600 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Suzuki GSX-S1000GT in one place.
2023 Suzuki GSX-S1000GT/GT+2023 Suzuki GSX-S1000GT/GT+
Motorcycle Overview​
  • Price: $13,349 USD / $16,099 CAD
    • Superbike-derived 999cc engine
    • Dunlop SPORTMAX Roadsport 2 radial tires
    • Suzuki Intelligent Ride System (S.I.R.S.)
    • Vibration-damping handlebars & footpegs
  • Engine: 999cc inline-four
  • Power: 150hp
  • Torque: 79.6 lb-ft
  • Weight: 498 lbs (226kg)
  • Seat Height: 31.9 inches (810mm)
  • Kawasaki Ninja 1000SX
2023 Suzuki GSX-S1000GT/GT Specifications​
Engine​
Engine999cc, 4-stroke, 4-cylinder, liquid-cooled, DOHC
Bore x Stroke73.4 mm x 59.0 mm (2.9 in. x 2.3 in.)
Compression Ratio12.2 : 1
Fuel SystemFuel injection
LubricationWet sump
Drivetrain​
Clutch
Final Drive
Chassis​
Suspension FrontFront Inverted telescopic, coil spring, oil damped
Suspension RearRear Link type, coil spring, oil damped
Brakes FrontDisc, twin
Brakes RearDisc
Tires Front120/70ZR17M/C (58W), tubeless
Tires Rear190/50ZR17M/C (73W), tubeless
Fuel Tank Capacity19.0 L (5.0 / 4.2 US/Imp gal)
Color
Electrical​
IgnitionElectronic ignition (CDI)
Spark Plug
Traction Control
ABSMotion Track Anti-lock Brake System with cornering ABS
Dimensions​
Overall Length2,140 mm (84.3 in.)
Overall Width825 mm (32.5 in.)
Overall Height1,215 mm (47.8 in.)
Ground Clearance
Wheelbase1,460 mm (57.5 in.)
Seat Height810 mm (31.9 in.)
Curb Weight226 kg (498 lbs.)
Warranty​
Warranty12-month limited warranty
2023 Suzuki GSX-S1000GT/GT Features​
PURE POWER AND RELIABILITY TO GO THE DISTANCE​
The new GT is powered by a high-performance 999 cm/four-stroke DOHC liquid-cooled inline-four engine developed to realize a true grand touring riding experience. The engine underwent a thorough review and updates to increase power output and achieve an even better balance of overall performance, all while satisfying Euro 5 emissions standards.
The new version delivers superbike-level performance while minimizing vibration to make riding more exciting, more comfortable and less tiring, whether travelling long distances on the highway or enjoying a ride around town. Its broad, smooth torque curve featuring greater cumulative torque production consistently delivers abundant power throughout the engine’s operating range and makes this grand tourer equally adept at street riding as it is at high-speed long-distance touring, even under load when carrying gear and a passenger on the back.
A CHASSIS ENGINEERED FOR REAL-WORLD ENJOYMENT​
The new GT delivers nimble handling and confidence-inspiring controllability, whether out touring long distances on the highway, negotiating twisty mountain roads, or simply enjoying its sporty performance on city streets. Every component of the chassis and running gear is engineered to bring you just the right balance of agility, stability and comfort for a true grand touring experience.
At the core is the compact, lightweight chassis design. The rigid twin-spar aluminum frame and ruggedly braced aluminum-alloy swingarm are key to great road holding ability that will go the distance, even when carrying a passenger and a full load of gear.
A SPORTY, YET PLUSH RIDE​
Fully adjustable ø43mm KYB inverted front forks and link-type rear suspension combine agility and stability with a ride that is sporty yet plush. Carrying all this to the road surface in harmony with the suspension settings are six-spoke cast aluminum wheels fitted with new Dunlop SPORTMAX Roadsport 2 radial tires designed specifically for the GSX-S1000GT.
The tires adopt an updated internal construction with a carcass that is custom-engineered exclusively for the GT and tuned to deliver just the right level of rigidity to match its weight and the riding conditions under which it will be used. Also introducing a new compound and optimized tread pattern, these new tires enhance grip in wet conditions, warm up faster and achieve better wear resistance.
INTELLIGENT CONTROL PERSONIFIED​
The Suzuki Intelligent Ride System (S.I.R.S.) introduces a collection of advanced electronic systems that let you optimize performance characteristics to best suit your riding style or level of riding experience, enhance operation, and help free you to concentrate on the ride. S.I.R.S. brings greater confidence and pleasure by making the new GT more controllable, more predictable, and less tiring, whether touring for long distances or enjoying a ride on your local streets.
S.I.R.S. Controls include:
Ride-by-wire Electronic Throttle System
Suzuki Drive Model Selector (SDMS)
Suzuki Traction Control System (STCS)
Bi-directional Quick Shift System
Low RPM Assist
Suzuki Easy Start System
Suzuki Clutch Assist System (SCAS)
CRUISE CONTROL SYSTEM​
Cruise control is a convenient new system that lets you maintain a set speed without operating the throttle. This helps reduce fatigue when touring long distances, particularly when travelling at constant speed on highways. You can easily adjust the speed setting up or down using the (+/-) select switch on the left handlebar and confirm the current setting on the TFT LCD instrument screen by pressing the left handlebar switch’s RES button. Cruise Control can be set at speeds between 30km/h to 180km/h while riding above 2,000rpm in second gear or higher.
COMFORTABLE UPRIGHT RIDING POSITION​
Extended handlebar length and grips angled closer to your body gives you greater control over steering and makes the bars more comfortable to hold. The result is reduced fatigue when touring long distances or enjoying a sporty run. This combines with a new seat design and slightly longer distance between the seat and footrests to realize an upright riding position that offers relaxing comfort on those long rides.
MAXIMUM COMFORT FOR A SMOOTH, RELAXING RIDE​
The GT features engineering to minimize vibration for an even smoother, more relaxing ride. No effort has been spared in designing the GT to isolate you and your passenger from vibration that might otherwise by transmitted from the engine or chassis. The GT adopts a new floating handlebar design that introduces rubber mounts in the top bridge and brackets to lessen the amount of vibration transmitted to your hands.
Special care went into designing the thickness, shape and size of the new rider and pillion seats, and both seats are covered in a new material that provides positive grip. New grab bars at the back of the pillion seat further contribute to passenger comfort.
One additional example is the vibration-absorbing rubber that covers the aluminum footrest pegs.
AERODYNAMICS AND WIND PROTECTION​
The GT’s new front cowl, windscreen and mirrors are all meticulously designed and extensively tested to achieve the level of aerodynamic efficiency and wind protection that is critically important to meeting the demands of high-speed touring, both in terms of dynamic performance and relaxing comfort.
Design priorities for the new windscreen focused keenly on maximizing wind protection, but also to keep the form as compact and attractive as possible. In addition to deflecting wind away from your head, folds introduced along the sides help protect your shoulders and knees.
BETTER VISIBILITY AND REDUCED FATIGUE​
The attractive new cowl-mounted mirrors and mirror stays streamline the flow of air and soften the force of wind that strikes your knuckles and hands for greater comfort and protection on those long rides. The design also reduces the amount of required eye movement, so helps make touring even more relaxing and less tiring.
The comfort and reduced fatigue that results from protection against wind, rain and cold better enable you to concentrate on riding so you can fully enjoy the GT’s outstanding performance on those long rides.
2023 Suzuki GSX-S1000GT/GT Photos​
2023 Suzuki GSX-S1000GT/GT+ 2023 Suzuki GSX-S1000GT/GT+ 2023 Suzuki GSX-S1000GT/GT+ 2023 Suzuki GSX-S1000GT/GT+
2023 Suzuki GSX-S1000GT/GT Videos​
Suzuki GSX-S1000GT Review – The Ultimate All-Rounder? by MOTOBOB:
Spending 2022 with the NEW Suzuki GSX-S1000GT by MCN:
SUZUKI Motorcycles Websites​
The post 2023 Suzuki GSX-S1000GT/GT+ [Specs, Features, Photos] appeared first on webBikeWorld.
