2023 Zero SR/F [Specs, Features, Photos]
Embrace the Electric Revolution With The 2023 Zero SR/F
The 2023 Zero SR/F is a stunning piece of machinery that’s packing a punch with its class-leading performance, connectivity features, and sleek design. The SR/F is powered by Zero’s new Z-Force 75-10 motor, backed up by a Z-Force 17.3 kWh lithium-ion battery. This translates into an exhilarating 140 foot-pounds of torque and 110 horsepower. Showcasing the ingenuity of this American motorcycle brand. Zero’s proprietary concentric motor and swingarm pivot design ensure constant drive-belt tension and maximum torque delivery to the rear wheel, providing you with optimal power transfer. Backing up that motor is a battery that allows an impressive 187 miles of range, meaning you can go further than ever on a single charge. And speaking of charging, this bike quick charges up in just one hour, keeping you on the road and out of the charging station.
Technology is a highlight of Zero’s latest 2023 lineup of bikes and this SR/F includes the Cypher III+ operating system, which is teeming with downloadable performance upgrades and customizable ride modes. Whether you’re cruising in the rain or carving in the canyons, the SR/F has a ride mode that fits.
Zero has all the “smart” tech you need on a motorcycle and is connected through cellular networks, transmitting info to the Zero app at all times. You can monitor your bike’s status, charge level, location, and more, all from your smartphone. It’s like having a digital co-pilot riding shotgun with you everywhere you go.
The SR/F hasn’t forgotten about comfort and has a seat height of 31 inches, making it accessible to riders of various heights. It tips the scales at 500 pounds, balancing heft and agility for a smooth, comfortable ride.
The 2023 Zero SR/F starts at $19,795 USD/$25,320 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Zero SR/F in one place.
2023 Zero SR/F2023 Zero SR/F
Motorcycle Overview​
  • Price: $19,795 USD/$25,320 CAD
    • 187 mile range with 1 hour quick charge
    • Cypher III+ operating system for customization
    • Cellular connectivity for monitoring
    • 124 Mph top speed
  • Engine: Z-Force 75-10 air-cooled, interior permanent magnet AC motor
  • Power: 110 horsepower
  • Torque: 140 ft-lbs
  • Weight: 500 lbs (227 kgs)
  • Seat Height: 31 inches (787 mm)
2023 Zero SR/F Specifications​
Motor​
Peak torque
140 ft-lb (190 Nm)
Peak power
110 hp (82 kW) @ 5,600
Top speed (max)
124 mph (200 km/h)
Type
Z-Force 75-10 enhanced thermal efficiency, passively air-cooled, interior permanent magnet AC motor
Controller
High fficiency and power dense, 900 Amp, 3-phase AC controller with regenerative deceleration
Lubrication
Drivetrain​
Clutch
Final Drive90T / 20T, Poly Chain® HTD® Carbon
belt
Chassis​
Suspension Front
Showa 43 mm Big Piston Separate Function forks, with adjustable spring preload, compression and rebound damping
Suspension RearShowa 40 mm piston, piggy-back reservoir shock with adjustable spring preload, compression and rebound damping
Brakes Front
Bosch Advanced MSC, dual J-Juan radial 4-piston calipers with radial master cylinder, 320 x 5 mm discs
Brakes Rear
Bosch Advanced MSC, J-Juan single piston floating caliper, 240 x 4.5 mm disc
Tires FrontPirelli Diablo Rosso III 120/70-17
Tires RearPirelli Diablo Rosso III 180/55-17
Fuel Tank CapacityN/A
Color
Power system​
Power pack
Z-Force® Li-Ion intelligent integrated
Charger type
6.6 kW integrated
Charge time (standard)2.7 hours (110% charged) / 2.0 hours (95% charged)
Dimensions​
Wheelbase
57.1 in (1,450 mm)
Overall Width
Trail
3.7 in (94 mm)
Rake
24.5°
Seat Height31.0 in (787 mm)
Curb Weight
500 lb (227 kg)
Warranty​
Warranty
2 years
Power pack warranty5 years/unlimited miles
2023 Zero SR/F Features​
Z-FORCE 17.3 BATTERY PACK​
The all new Z-Force 17.3 kWh lithium-ion battery makes the SR/F capable of a 227-mile maximum range. The battery’s industry-leading power and energy density combined with an aluminum heat-sink housing and thermal transfer interface ensure consistent cell cooling and maximum long-term powertrain performance. Additionally, the available 3.6 kWh Power Tank brings the total available battery capacity to nearly 21 kWh.
RAPID CHARGE SYSTEM​
Our scalable Rapid Charge System allows the bike to be configured for different charging levels. Model Year 2023 SR/S 6 kW comes fully upgraded to 6.6 kW thanks to the included the Cypher Upgrade. In addition, you can purchase an additional 6 kw charging module (dealer install required) that can get you up to 12.6 kW. * Note: SR/S requires the use of included EVSE cord in order to charge on a standard 110 V wall outlet.
Z-FORCE 17-10 MOTOR​
The Z-Force 75-10 motor delivers 140 ft-lbs of torque and 110 hp, effortlessly propelling the SR/F to a top speed of 124 mph. Pairing Zero’s renowned internal permanent magnet brushless architecture and a passively air-cooled compact design creates class-leading performance and efficiency.
Incredibly light. Unbelievably strong. The steel-trellis frame, custom swingarm and advanced Showa suspension deliver an athletic and intuitive riding experience. The powertrain is perfectly distributed, resulting in a weight-optimized/mass-centralized design, while a dual radial front brake system makes shedding speed as exhilarating as building it.
BOSCH MOTORCYCLE STABILITY CONTROL​
The SR/S is the first electric motorcycle to integrate Bosch’s MSC System, renowned for dynamic acceleration and improved stability regardless of road surface or conditions. When combined with Cypher III+, the MSC’s full capabilities are unleashed, resulting in best-in-class straight-line ABS and cornering brake control, traction control, and drag torque control.
DASH​
Customize your dash. Choose the bike info you want and see it clearly on the full-color 5” TFT display. Multi-mode navigation enables on-the-fly ride mode switching, cruise-control, heated-grips control and much more.
2023 Zero SR/F Photos​
2023 Zero SR/F 2023 Zero SR/F 2023 Zero SR/F 2023 Zero SR/F
2023 Zero SR/F Videos​
2023 Zero SR/F Review by Visordown Motorcycle Videos:
2023 Zero SR/F review by Beards ‘n Cars:
Zero Motorcycles Websites​
The post 2023 Zero SR/F [Specs, Features, Photos] appeared first on webBikeWorld.
