JoeZ
Hi, was wondering if it was possible to simply connect 2 fog light wires directly into a battery tender cable ... Simplifying connection and wiring.
Sure but how would you control the fog lights? They would be on all the time even with the key off. If the idea is to use it as an easy power source your still going to have to install a relay and the control so you might as well take the side plastics off and wire it properly.
I ordered some cheap lights from china some battery tender wires and spliters and an on/off switch.... and will do some experimenting ... If all goes well, in two weeks I'll post my results. ))
Actually they do sell the battery tender with the fuse connections plus 10 or 16 gauge wiring.
link for that? I think I'd like to try the SAE (battery tender) connection method. Would not be hard to wire in a simple ON/OF switch and make it manual.
Maybe we could put together a list of things required to accomplish it?
No NC700, at least in the USA, comes from the factory with an SAE connector and harness to the battery already installed. If it had one when you bought it, the dealer installed it.
