orlando
Has anyone had the clutch lever stick to the pivot bolt? I have tried an impact driver and not got it to budge.
Just to be clear, and referencing the attached parts illustration, are you stating that nut 21 is removed, yet bolt 20 is stuck to the lever 13 and the bolt and lever move as one? I have not heard of that happening.Has anyone had the clutch lever stick to the pivot bolt? I have tried an impact driver and not got it to budge.
Yep just put new clutch lever on yesterdayAfter the lock nut was removed I thought the pin also had to be unscrewed.
Yes. I just replaced the perch and lever. Need advice on removing the switch.Has anyone had the clutch lever stick to the pivot bolt? I have tried an impact driver and not got it to budge.
