How To Corrosion on the block
ash.nc700x
Derby uk
Hello everyone,
I currently own a 2012 NC700X with 50,000 miles and a 2021 NC750X with 10,000 miles. I've noticed that the engine block on my 700 looks fine, while the one on my 750 has significant corrosion. Interestingly, my 700 is used for commuting year-round in all weather conditions, including English winters with lots of road salt, while my 750 is stored in the garage with a cover over it during the winter months and only used in nice weather. I'm puzzled as to what could have caused such severe corrosion on the 750. Any insights or advice would be greatly appreciated.
see the attached photos and you will see what I am talking about.
Thanks,
Ash
it's funny back when there was a UK CB1100 forum and a USA CB 1100 forum, the guys in the UK complained about corrosion on their bikes, particularly the cylinders, which was never an issue on the USA forum
What I am not understanding is why would a bike that is well looked after getting all that corrosion but the bike that is run in every weather imaginable is fine
It may be from coolant if it has accidentally spilled or leaked onto the surface of the engine block.
Or it could be from humid air mixed with salt water. If you live relatively close to the ocean, many stormy weather events carry large amounts of seawater mixed with air. In one of your photos there are also bright spots on the surface of this black bar (engine guard?).
It won't do much damage to the alloy engine block. Just wash it off with warm water and neutral detergent and rinse with water.
If this persists, wash the entire motorcycle more often, using only neutral detergent and compressed air to remove most of the water.
Taste the white furry stuff (gingerly). It does look like what road salt turns into when left in a moist atmosphere.
Is the place you store the bike in ventilated? Condensation can be a problem if your shed is wet/damp.
If you are going to store the bike over winter dose it with with a protector like ACF-50 if you aren't already.
