ADWaddell
Does anyone out there make an accessory pushbutton to open the frunk instead of having to use the key to open it? It's annoying if I'm at a long left-turn stoplight or similar and would like to get into my frunk to take a quick sip of water or something. It's way too fiddly to hit neutral, shut the bike off, pull the keys, put it into the frunk, open the frunk, grab the water bottle, take a quick drink, throw the bottle back in, lock it up, get the keys back out, put them in the ignition and get the bike restarted and reselect the gears. A lot of screwing around for something that should take 10 seconds at the most if there was someone making an accessory for the frunk that is a pushbutton to release the frunk instead of an ignition key required.
Ideally, the pushbutton would also have a lock feature, so if you wanted to you could lock it when you're leaving the bike, but could unlock it to be a pushbutton access when you ride. Betcha I'm not the only one who is frustrated with the unusability of the frunk without having to do all the fiddling. (2018 NC750XD if it matters).
