LED Headlight
ST13Fred
Proctor WV USA
The C125A Cub headlight has 10 bulbs. The upper half is low beam and bottom half hi. There's a narrow yellow looking diffuser lens running across the middle.
I'm curious how the 2018 headlight is arranged.
Halogen lo/hi. Both halogen and LED have some 10/2 o'clock spray,
meaning the LED is a pretty close match to the OEM headlight assembly.
LED hi/lo. A little bit of spray at 10/2 o'clock not bad and w/the clear lens really pretty light.
The OEM LED is odd looking. A clear lens and segmented chrome reflector is easy on the eyes, no pun intended, especially w/LED.
Looks nice. Have you ridden with it at night yet? I need to look at mine more closely to see if there is any vertical adjustment to it at all.
The lights position is much too low in the road on low beam to ride safely above 35mph(imho) and I don’t want to be “that guy” and run high beam all the time. MyCroft I stalled a really nice/bright LED light of some kind and though I like it I just want to adjust it up a little bit.
Yes and a white LED/HID are worlds better than the yellow Halogen at night..
In the 90s' I rode to work before daylight and always noticed the new to the road HID set ups coming along side and passing. They lit up the whole roadway.
