Yamaha Drops the R1 GYTR PRO 25th Edition
Yammie’s celebrating 25 years of their iconic R1 with a new GYTR PRO!
For those of you who don’t know, Yamaha’s GYTR PRO models are made with the same people responsible for punting out the Iwata WorldSBK machines; as such, top-tier pieces are a must – even Yamaha herself is claiming that this new model “will bring World Superbike levels of spec and performance to the R1 range” (via Visordown).
A view of Yamaha's 2023 GYTR Pro. Media sourced from Visordown.
A view of Yamaha’s 2023 GYTR Pro. Media sourced from Visordown.
The above may feel like hefty praise, but hold your doubt until you get a load of the big-buck stuff this R1 GYTR PRO 25th Edition is getting:
  • Carbon sub-frame
  • Modified fuel tank
  • Magneti Marelli ECU
  • Öhlins FGR front suspension
  • TTX rear shock, (complete with a pneumatic preload adjuster)
  • WorldSBK-spec underslung swingarm
  • Brembobrakes (front and rear)
  • Carbon fibre bodywork
Not enough for you?
Don’t worry – Yamaha can also upgrade the 2023 R1 GYTR PRO 25th Edition to accept the GYTR Pro Electronic System (GPES) – an electronics engine package module, which gives you the following:
  • Anti-Wheelie
  • Launch Control
  • Engine Braking Management
  • Adjustable Fuelling
  • Traction Control
Only 25 of these special bikes will be made for Europe, so if you’re in the area, be sure to place that wallet down; once the bike is built, we’re told that “the 25 owners will then get the chance to have the bike set up for them by a team of Yamaha technicians and will receive the same level of service that the factory’s WorldSBK riders are given.”
Looking forward to seeing the continued legacy of the R1’s 25-year reign.
*Media sourced from Visordown*​
The post Yamaha Drops the R1 GYTR PRO 25th Edition appeared first on webBikeWorld.
