The 2021 Harley Davidson Road King: Long Live The King
The Road King is the classic entry-level bagger in the 2021 Harley Davidson lineup. With no real changes from the 2020 model, there have been some rumors that this could be the last year of the All American legend Road King.
The smooth 110 lbs-ft of torque from the Milwaukee-Eight® 107 V-twin, easily power you down the highway, enjoying mile after mile listening to the classic Harley Davidson rumble. A removable fork-mounted fairing keeps the wind off your chest, and the one-touch opening hard bags hold plenty for longer trips.
3 colors for the 2021 Harley Davidson Road King: Vivid Black, Billiard Red, Midnight Crimson & Stone Washed White Pearl
The 2021 Harley Davidson Road King starts at $19,499 USD / $23,899 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Harley Davidson Road King in one place.
- Price: $19,499 USD / $23,899 CAD
- Reflex
- One-Touch Opening Saddlebags
- ABS & Cruise Control Standard
- Removable Fairing
- Reflex
- Engine: 107 ci V-twin
- Power: 92.5 HP (estimated)
- Torque: 110 lbs-ft @ 3000 RPM
- Wet Weight: 828 lbs (375 kg)
- Seat Height: 26.3 inches (705 mm)
- Indian Springfield
- BMW R18 Classic
- Moto Guzzi California
2021 Harley Davidson Road King Specifications
Engine | 107 ci V-twin, Milwaukee-Eight® 107 |
Engine Torque | 110 lbs-ft @ 3000 RPM |
Bore x Stroke | 3.937 in. in x 4.374 in |
Compression Ratio | 10.0:1 |
Fuel System | Electronic Sequential Port Fuel Injection (ESPFI) |
Exhaust | Chrome, 2-1-2 dual exhaust with tapered mufflers |
Clutch | |
Transmission | 6-speed |
Primary Drive | Chain, 34/46 ratio |
Wheels, Front Type | Slicer II Cast Aluminum |
Wheels, Rear Type | Slicer II Cast Aluminum |
Brakes Front | 32 mm, 4-piston fixed |
Brakes Rear | 32 mm, 4-piston fixed |
Tires Front | BW 130/70B18 63H |
Tires Rear | BW 180/55B18 80H |
Fuel Tank Capacity | 6 gal. |
Color | Vivid Black, Billiard Red, Midnight Crimson & Stone Washed White Pearl |
Ignition | |
Headlight | High beam |
Tail Light | LED |
Overall Length | 96.5 in. |
Trail | 6.7 in. |
Rake | 26 |
Wheelbase | 64 in |
Ground Clearance | 5.3 in.. |
Seat Height | 26.3 in. |
Weight, As Shipped | 794 lb |
Warranty | |
Extension |
2021 Harley Davidson Road King Features
Milwaukee-Eight® 107 Engine
A powerful, smooth-running engine with crisp throttle response and a pure, soul-satisfying rumble.Reflex
Linked Brembo® Brakes with Standard ABS
Designed to help prevent the wheels from locking under braking to assist the rider in maintaining control when braking in a straight-line. ABS operates independently on front and rear brakes to keep the wheels rolling and help prevent uncontrolled wheel lock in urgent situations.Hiawatha Headlamp and Nacelle
Born in the ’60s, when chrome ruled the streets. Big and commanding, it’s built with the latest in materials and technology for a long distance high beam and wide low beam.Responsive Suspension
High-performing front and rear suspension, with easily hand-adjustable rear shocks put you in control of a plush ride.Slicer II Cast Aluminum
A 18-inch front and 18-inch rear Slicer II wheel to match in the back are stunning and lightweight.One-Touch Opening Saddlebags
Tight on the outside, roomy on the inside. The hinges are simple and clean and the lids open with one touch of one hand.2021 Harley Davidson Road King Photos
2021 Harley Davidson Road King Videos
Harley-Davidson Official Websites
The post 2021 Harley Davidson Road King [Model Overview] appeared first on webBikeWorld.
