The 2022 Indian Scout: An Iconic Moniker That Has Been around for over a Century
The Indian Scout is an iconic motorcycle from the stable of the first American motorcycle manufacturer, Indian Motorcycle. The 2022 Indian Motorcycle lineup is extensive, with a total of seven Scout models; the Indian Scout sits at the very top, alongside the Scout Bobber Twenty.
Powering the Scout is a 1,133cc engine, renowned for its strong mid-range and top-end performance. Peak output figures are 100 hp and 72 lb-ft of torque, and this power is transmitted to the rear wheel via a six-speed gearbox and a low-maintenance belt drive.
While the Indian Scout resembles its namesake from over a century ago, this present-day iteration comes with some modern features. Riders will have access to cruise control, ABS, a digi-analog instrument cluster with a USB port, and grippy Pirelli tires. Other notable elements include forward-set footpegs for relaxed long-distance riding, a genuine leather seat, and loads of embellishments.
For 2022, the Indian Scout is available in two new color schemes — Maroon Metallic and Silver Quartz Metallic over Black Metallic — in addition to the four existing colorways. This year also sees the introduction of a new 146 mm (5.75-inch) Pathfinder Adaptive LED Headlight accessory, available for all Scout models.
The 2022 Indian Scout starts at $13,249 USD / $16,499 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Indian Scout in one place.
Motorcycle Overview
- Price: $13,249 USD / $16,499 CAD
- Iconic American styling
- 1,133cc V-twin engine with strong mid-range and top-end
- Low seat height for easy accessibility and control
- Engine: 1,133cc V-twin
- Power: 100 hp
- Torque: 72 lb-ft
- Wet Weight: 561 lbs (254 kg)
- Seat Height: 25.6 in (649 mm)
2022 Indian Scout Specifications
Engine | 1133cc, Liquid Cooled V-Twin (60 degrees) |
Engine Power | 100 HP |
Bore x Stroke | 3.898 in x 2.898 in (99 mm x 73.6 mm) |
Compression Ratio | 10.7:1 |
Fuel System | Closed Loop Fuel Injection / 60 mm Bore |
Exhaust | Split Dual Exhaust w/ Cross-over |
Clutch | Wet, Multi-Plate |
Transmission | 6 Speed |
Final Drive | 2.357 : 1 |
Suspension Front | 41 mm, Telescopic Fork |
Suspension Rear | Dual Shocks |
Brakes Front | Single / 298 mm Rotor / 2 Piston Caliper |
Brakes Rear | Single / 298 mm Rotor / 1 Piston Caliper |
Tires Front | Pirelli Night Dragon 130/90B16 67H |
Tires Rear | Pirelli Night Dragon 150/80B16 77H |
Fuel Tank Capacity | 3.3 gal (12.5 L) |
Color / Graphics | Black Metallic, Black Metallic ABS, Maroon Metallic ABS, White Smoke ABS, Silver Quartz Metallic / Black Metallic |
Ignition | |
Headlight | LED Headlamp |
Tail Light | LED Taillight |
Overall Length | 91.5 in (2,324 mm) |
Overall Width | 36.1 in (916 mm) |
Overall Height | 42 in (1,068 mm) |
Wheelbase | 5.7 in (146 mm) |
Ground Clearance | 5.7 in (146 mm) |
Seat Height | 25.6 in (649 mm) |
Weight (Empty Tank / Full of Fuel) | 541 lbs (245 kg) / 561 lbs (254 kg) |
Warranty | 2 Years, Unlimited Miles |
Extension |
2022 Indian Scout Features
Originality Comes Standard
A name that goes back a century. An experience that lives up to the legacy. The Scout is where heritage-inspired design meets modern performance.100 Horses. Unleashed.
The liquid-cooled, 69-cubic-inch, 100 hp V-twin delivers punchy acceleration and the power to pass anyone, anywhere. Electronic fuel injection delivers class-leading horsepower and acceleration, while a responsive 6-speed transmission allows for sporty, aggressive riding.Draped in Chrome
Premium chrome provides plenty of head-turning shine. Make a statement that’s sure to get noticed.Two-Up Riding
A genuine leather two-up seat is designed to withstand the elements while maintaining its natural beauty. Passenger pegs standard.19" front wheel
The 19-inch front wheel adds to the aggressive nature of the Scout Rogue Sixty – both in style and agile handling.Ride With Confidence
A low seat height and a lightweight frame makes for an easy, confident ride at every speed.Always Charging
The hidden USB port makes it easy to keep your devices in the green, meaning you don’t have to sacrifice style for modern function.Full Stop
Superior stopping power with ABS standard on all color options.2022 Indian Scout Photos
2022 Indian Scout Videos
Which Indian Scout is For You? By Indian Motorcycle:
Indian Scout Comprehensive Review by Yammie Noob:
The post 2022 Indian Scout [Specs, Features, Photos] appeared first on webBikeWorld.
