The 2022 MV Agusta F3 RC Is Pure Racing Tradition
The MV Agusta F3 RC is the maximum expression of motorbike sportiness in the Italian brand’s 2022 lineup. Of course, we can find other versions developed by the ‘Reparto Corse’ department, but the F3 is the pure sports version of the brand.
It’s no secret that all the details of this supersports bike focus on exclusivity and performance on the track. For instance, only 200 units of this model will be manufactured. These sport the brand’s official colors in competition, each engraved with the serial number on the stem and a certificate of authenticity.
The MV Agusta F3 RC supersport has a racing approach true to its Italian heritage. The first example is the fork with a titanium nitride treatment, a ceramic that reduces friction. In addition, the wheels reduce weight by 10%, which translates into a moment of inertia reduced by 7%. All this allows dynamic improvements that bring it closer to competition motorcycles.
Finally, it is worth mentioning the possibility of installing a racing kit for the circuit made up of special parts: Akrapovič full exhaust in titanium with carbon fiber temperature protector, a specific control unit with maps suitable for the track, and mechanized CNC competition footpegs and levers to turn the F3 into a true track beast.
The 2022 MV Agusta F3 RC starts at $28,498 USD / $31,500 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 MV Agusta F3 RC in one place.
- Price: $28,498 USD / $31,500 CAD
- 147 hp 798 cc 3-cylinder engine
- Continental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function
- Integrated ignition – injection system MVICS 2.1 (Motor & Vehicle Integrated Control System) with six injectors
- Front Marzocchi “UPSIDE DOWN” telescopic hydraulic fork with TIN treatment and rear progressive Sachs, single shock absorber. Both suspensions feature rebound and compression damping and spring preload adjustment.
- Engine: 798 cc, 4-stroke, 3-cylinder, liquid-cooled, 12 valve DOHC
- Power: 147 hp (108 kW) at 13,000 rpm
- Torque: 65 lb-ft (88 Nm) at 10,100 rpm
- Wet Weight: 421 lbs (191 kg)
- Seat Height: 32.6 in. (830 mm)
- Ducati Panigale V2 Bayliss 1st Championship 20th Anniversary
- Suzuki GSX-R750
- Yamaha XSR900
2022 MV Agusta F3 RC Specifications
Engine | 798 cm3 (48.7 cu. in.), Three cylinders, 4 stroke, 12 valves |
Power | 147 Hp |
Bore x Stroke | 79 mm x 54.3 mm (3.1 in. x 2.1 in.) |
Compression Ratio | 13.3:1 |
Timing system | “D.O.H.C” with mechanical chain tensioner and DLC tappet |
Color | Matt Fired Red, Matt SV Ago Magnum Silver, Matt Ago Yellow |
Clutch | Wet, multi-disc slipper clutch |
Transmission | Cassette style; six speed, constant mesh |
Final Drive Ratio | 17/43 |
Suspension Front | Öhlins Nix “UPSIDE DOWN” telescopic hydraulic fork with rebound-compression damping and spring preload external and separate adjustment |
Suspension Rear | Progressive Öhlins TTX, single shock absorber with rebound and compression damping and spring preload adjustment |
Brakes Front | Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange |
Brakes Rear | Single steel disc with Ø 220 mm (Ø 8.66 in.) dia. |
Tires Front | 120/70 – ZR 17 M/C (58 W) Pirelli Diablo Rosso Corsa II |
Tires Rear | 180/55 – ZR 17 M/C (73 W) Pirelli Diablo Rosso Corsa II |
Fuel Tank Capacity | 16,5 l (4.36 U.S. gal.) |
ABS System | Continental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function |
Battery | 12 V – 8.6 Ah |
Voltage | 12 V |
Alternator | 350 W at 5.000 r.p.m. |
Headlight | |
Tail Light | |
Overall Length | 2.015 mm (79.92 in.) |
Overall Width | 760 mm (28.74 in.) |
Trail | 99 mm (3.89 in.) |
Wheelbase | 1.380 mm (54.33 in.) |
Ground Clearance | 120 mm (4.72 in.) |
Seat Height | 830 mm (32.68 in.) |
Dry Weight | 173 kg (381.4 lbs.) – 165 kg (363,8 lbs.) |
Warranty | |
Extension |
2022 MV Agusta F3 RC Features
Electronics
Electronics package is focused on the MVICS 2.1 platform, which controls 6 fuel injectors, interfaces with the inertial platform, manages 4 engine maps and 8-level traction control. In addition, the MV EAS 3.0 (Electronically Assisted Shift up & down) contributes to offering even more lightning-fast and precise shift changes. The new Superveloce Ago features a special kit, which includes a control unit that allows the rider to get the most out of the road-approved Arrow exhaust system (optional).Technology
The new Superveloce Ago unique kit includes the captivating Arrow exhaust system (road-approved), immediately recognizable by two tail pipes on the right side and one on the left; the triple overlapping muffler is instead fitted as standard. What’s more, the Arrow asymmetrical exhaust not only significantly guarantees an increase in power and torque but also contributes to intensify the Superveloce Ago sporty character. To be true, this new-born seems to remember the racing bikes of the past, protagonists of many glorious victories. The MV Agusta Superveloce Ago kit overwhelms also thanks to numerous carbon fibre components, included the seat cowl fitted with Alcantara pad, a pair of appealing red grips, a special bike cover as well as a certificate guaranteeing the authenticity of the limited series.Safety
Like all the bikes in the Superveloce range, the Ago limited edition boasts a rich safety package, starting with the Brembo braking system. This choice guarantees not only extraordinary on-road and track performance, specifically in terms of power and control, but also the whole system takes advantage of the ABS Continental MK100 module, which includes cornering function. The result? Safe braking, thanks to active anti-lock braking even when cornering.2022 MV Agusta F3 RC Photos
2022 MV Agusta F3 RC Videos
2022 MV Agusta Superveloce Ago UNBOXING
NEW 2022 MV Agusta Superveloce Ago Edition: 5 Best Features!
MV Agusta Websites
Other Links
The post 2022 MV Agusta F3 RC [Specs, Features, Photos] appeared first on webBikeWorld.
