2022 MV Agusta Turismo Veloce Lusso [Specs, Features, Photos]
2022 MV Agusta Turismo Veloce Lusso: Higher Performance for Any Journey​
MV Agusta has updated the Veloce Lusso for the 2022 model year with improved equipment, electronics, and design with new finishes.
At the engine level, this motorbike equips a 798 110 hp cc three-cylinder engine complemented by an anti-rebound clutch.
This Italian-made sport touring bike relies on torque and traction control with tilt adjustment, electronic throttle, and electronic up and down gear change to manage the power. Regarding the cycle part, the Lusso keeps the tubular steel chassis with aluminum plates on the frame.
The suspension comprises a front telescopic fork and Sachs MVCS semi-active electronic suspension system. The rear suspension is handled by a Sachs monoshock absorber with preload regulation.
In the braking department, we find 4-piston Brembo radial calipers up front and a 2-piston caliper in the rear. All this works with the Bosch 9 PLUS ABS with the RLM system, which prevents the rear wheel from lifting during heavy braking. In addition, the heated grips stand out at the equipment level along with Full LED lighting.
The design of the Turismo Veloce / Lusso has undergone slight changes, maintaining the same stylized fairing with two glove compartments behind the screen. The standard triple outlet exhaust has also changed in this version with a quadrangular finish.
The 2022 MV Agusta Turismo Veloce Lusso starts at $20,400 USD / $28,800 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 MV Agusta Turismo Veloce Lusso in one place.
  • Price: $20,400 USD / $28,800 CAD
    • 110 hp 798 cc 3-cylinder engine
    • Continental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function
    • Front Sachs “UPSIDE DOWN” semi-active telescopic hydraulic fork MVCSC (MV Agusta Chassis Stability Control) and rear semi-active single shock absorber with hydraulic spring preload adjustment MVCSC
    • Front Brembo radial-type caliper with four pistons
Main Specs​
  • Engine: 798 cc, 4-stroke, 3-cylinder, liquid-cooled, 12 valve DOHC
  • Power: 110 hp (81 kW) at 10,150 rpm
  • Torque: 59 lb-ft (80 Nm) at 7,100 rpm
  • Wet Weight: 438 lbs (199 kg)
  • Seat Height: 32.68 in. (830 mm)
Competitors​
2022 MV Agusta Turismo Veloce Lusso Specifications​
Engine798 cm3 (48.7 cu. in.), Three cylinder, 4 stroke, 12 valve
Power110 Hp
Bore x Stroke79 mm x 54.3 mm (3.1 in. x 2.1 in.)
Compression Ratio12.3:1
Timing system“D.O.H.C” with mechanical chain tensioner and DLC tappet
ColorFire red, Matt Metallic Dark Grey
ClutchHydraulic, wet, multi-disc with slipper clutch
TransmissionCassette style; six speed, constant mesh
Final Drive Ratio16/39
Suspension FrontSachs “UPSIDE DOWN” semi-active telescopic hydraulic fork MVCSC (MV Agusta Chassis Stability Control)
Suspension RearProgressive Sachs, semi-active single shock absorber with hydraulic spring preload adjustment MVCSC (MV Agusta Chassis Stability Control)
Brakes Front
Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange
Brakes RearSingle steel disc with Ø 220 mm (Ø 8.66 in.) dia.
Tires Front120/70 – ZR 17 M/C (58 W)
Tires Rear190/55 – ZR 17 M/C (75 W)
Fuel Tank Capacity21.5 l (5.68 U.S. gal.)
ABS SystemContinental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function
Battery12 V – 11 Ah
Voltage12 V
Alternator450 W at 5.000 r.p.m.
Headlight
Tail Light
Overall Length2.125 mm (83.66 in.)
Overall Width910 mm (35.83 in.)
Trail108 mm (4.25 in.)
Wheelbase1.445 mm (56.89 in.)
Ground Clearance140 mm (5.51 in.)
Seat Height830 mm (32.68 in.)
Dry Weight191 kg (421.1 lbs.)
Warranty
2022 MV Agusta Turismo Veloce Lusso Features​
Electronics​
The added innovations are substantial: starting with the new inertial platform, developed exclusively for MV Agusta. The precision of the traction control and ABS have benefited, partly thanks to the dedicated programming for this specific model.
Technology​
To make your journey even more pleasurable, the new Turismo Veloce is fitted with semi-active Sachs suspension, with further optimised adjustments. Ergonomic analysis inspired us to redesign the entire central block of the bike, reducing the height of the saddle by a whole 25 mm.
Safety​
The satellite-aided anti-theft system, included as standard, is just one of example of the attention to security. The stunning elegance of the Lusso outfitting, in addition, is a yardstick for the entire category.
2022 MV Agusta Turismo Veloce Lusso Photos​
2022 MV Agusta Turismo Veloce Lusso 2022 MV Agusta Turismo Veloce Lusso 2022 MV Agusta Turismo Veloce Lusso 2022 MV Agusta Turismo Veloce Lusso
2022 MV Agusta Turismo Veloce Lusso Videos​
2022 MV Agusta Turismo Veloce Lusso Review | Daily Rider
2022 MV Agusta Turismo Veloce Lusso Dyno Test
MV Agusta Websites​
Other Links​
The post 2022 MV Agusta Turismo Veloce Lusso [Specs, Features, Photos] appeared first on webBikeWorld.
