The 2023 BMW R nineT Pure Is Minimalist Yet Modern
With the 2023 BMW R nineT Pure, BMW has created a stripped-down, minimalist motorcycle that combines classic styling with modern performance. This bike features a powerful 1,170cc boxer engine that delivers 109 horsepower which provides plenty of power for most any riding situation. The Pure’s simplified design includes a single round headlight, a classic round instrument cluster, and a sleek fuel tank with knee pads. The bike’s suspension system features a 43mm fork and an adjustable rear shock with preload and rebound damping options to ensure a comfortable ride. If you’re wanting to enhance the look of the Pure, much like their other bikes, BMW has provided many options. While there are other European choices in this category, the BMW R nineT Pure is a versatile motorcycle that offers a unique blend of retro style and modern performance, making it an excellent choice for riders who value simplicity and minimalism.
The 2023 BMW R nineT Pure starts at $10,995 USD, $13,845 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 BMW R nineT Pure in one place.
- Price: $10,995 USD, $13,845 CAD
- Speedometer with on board computer
- Ride Modes: Rain & Road
- LED headlight
- Drive train and final drive in black
- Engine: 1,170 cc air/oil cooled two-cylinder four-stroke boxer
- Power: 109 horsepower
- Torque: 85 lb-ft
- Weight: 483 lbs (219 kgs)
- Seat Height: 31.7 inches (805 mm)
2023 BMW R nineT Pure Specifications
Engine | 1170cc, Air/oil-cooled two-cylinder, four-stroke boxer engine with two camshafts and four radially arranged valves per cylinder as well as central counterbalance shaft |
Engine Power | 109 hp at 7,250 rpm |
Bore x Stroke | 101 mm x 73 mm |
Compression Ratio | 12.0 : 1 |
Fuel delivery | Electronic port fuel injection |
Max Torque | 85.5 lbs-ft. at 6,000 rpm |
Clutch | Single dry plate clutch, hydraulically operated |
Transmission | Constant mesh 6-speed gearbox with helical gear teeth |
Drive | Shaft Drive |
Suspension Front | Telescopic forks with 43 mm fixed-tube diameter |
Suspension Rear | Cast aluminum single-sided swing arm with BMW Motorrad paralever, central spring strut, spring preload continuously adjustable by handwheel, rebound damping continuously adjustable |
Brakes Front | Twin-disc brakes, diameter 12.6″, 4-piston calipers |
Brakes Rear | Single disc brake, diameter 10.4″, double-piston floating caliper |
Tires Front | 120/70 ZR 17 |
Tires Rear | 180/55 ZR 17 |
Fuel Tank Capacity | 4.5 gal. |
Color | Option 719 Underground/Light White, Option 719 Pollux Metallic/Light White, Mineral Gray Metallic |
Alternator | Three-phase alternator with 720 Watt nominal power |
Battery | 12 V / 12 Ah |
Headlight | |
Tail Light | LED Tail Light |
Length | 82.9” |
Width | 34.8” |
Height | 48.8” |
Wheelbase | 58.5” |
Castor | 4.1″ |
Seat Height | 31.7” |
Unladen weight, road ready, fully fueled | 483 lbs |
Warranty | |
Extension |
2023 BMW R nineT Pure Features
Adjustable spring strut
The new shock absorber with progressive damping is not only striking and eye-catching, but is also functional as it can also be manually adjusted using the knob.Modern LED turn indicators
The LED indicators ensure a highly visible appearance from all perspectives and more visibility when turning.Twin-cylinder boxer engine
The design of the engine looks even tidier with the new cylinder head covers and throttle bodies.Compact tank
With its design it unmistakably speaks the language of the R nineT family.Classic round speedometer
In the style of classic BMW roadsters, the analog classic circular instrument shows you only what you really need to ride.Single-pipe exhaust system
The silencer underlines the Pure’s traditional roadster look.Classically-painted front-wheel cover
The painted front-wheel cover rounds off the appearance consistently.LED headlights are standard equipment
Classic look, modern technology: The R nineT Pure now comes with an LED headlight standard.2023 BMW R nineT Pure Photos
2023 BMW R nineT Pure Videos
2023 BMW R nineT Pure review by: MotoBob
2023 BMW R nineT Pure review by Faceless Thrills:
BMW Official Websites
The post 2023 BMW R nineT Pure [Specs, Features, Photos] appeared first on webBikeWorld.
