The 2023 Harley Davidson Low Rider S/ST: It Just Got Better
Introduced last year, the Low Rider S and ST models deliver maximum power and performance thanks to the brilliant Milwaukee-Eight
Both the Lowrider S and ST models share the classic American Softail style, with the ST adding lockable saddle bags and a badass frame mounted fairing. The rear suspensions sit a little higher, as do the pipes, making it very obvious this bike wants you to lean into the curves.
Blacked out, bars raised, with a deep seat to keep you planted, the Low Rider bikes deliver all the parts you want, and skip all the fluff. From a dollars per point of performance measurement, this is the Harley Davidson motorcycle to choose.
2 color choices exist for the 2023 Harley Davidson Low Rider S/ST: Vivid Black, and White Sand Pearl.
The 2023 Harley Davidson Low Rider S starts at $18,199 USD / $24,249 CAD.
The 2023 Harley Davidson Low Rider ST starts at $22,199 USD / $27,649 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Harley Davidson Low Rider S/ST in one place.
- Price: $18,199 USD / $24,249 CAD – $22,199 USD / $27,649 CAD
- Milwaukee-Eight
- West Coast Styling
- ST offers a bagger style option
- Improved Rear Mono-Shock
- Milwaukee-Eight
- Engine: 1,923cc V-twin
- Power: 103 HP / 77 kW @ 4750 rpm
- Torque: 126 lbs-ft @ 3500 RPM
- Wet Weight: 679 lbs (308 kg)
- Seat Height: 28 in. (710 mm)
- Indian Chief Dark Horse
- Triumph Rocket 3 GT
- BMW R18-B
2023 Harley Davidson Low Rider S/ST Specifications
Engine | 1,923cc V-twin, Milwaukee-Eight® 117 |
Engine Power | 103 HP / 77 kW @ 4750 rpm |
Bore x Stroke | 4.075 in x 4.5 in. |
Compression Ratio | 10.2:1 |
Fuel System | Electronic Sequential Port Fuel Injection (ESPFI) |
Exhaust | 2-into-2 offset shotgun; catalyst in muffler |
Clutch | |
Transmission | 6-speed |
Primary Drive | Gear, 34/46 ratio |
Front Fork | Single cartridge 43 mm inverted with aluminum fork triple clamps; triple rate spring |
Rear Fork | Hidden, free piston, coil-over monoshock; 56 mm stroke; hydraulic preload adjustment |
Wheels, Front Type | Dark bronze, Radiate cast aluminum wheel |
Wheels, Rear Type | Dark bronze, Radiate cast aluminum wheel |
Brakes Front | 4-piston fixed front |
Brakes Rear | 2-piston floating rear |
Tires Front | 110/90B19,62H,BW |
Tires Rear | 180/70B16,77H,BW |
Fuel Tank Capacity | 5 gal. |
Color | White Sand Pearl, Vivid black |
Ignition | |
Headlight | High beam |
Tail Light | LED |
Length | 93.1 in. |
Trail | 5.7 in. |
Rake | 28 |
Wheelbase | 63.6 in. |
Ground Clearance | 5.7 in. |
Seat Height | 27 in. |
Weight, As Shipped | 650 lb. |
Warranty | |
Extension |
2023 Harley Davidson Low Rider S/ST Features
REAR SHOCKS
Preload adjustable monoshock.SPEEDOMETER
Handlebar mounted speedometer makes it easy to view while on the roll. Tucking it behind the fairing helps the bike keep its sleek look.HANDLEBARS
One-inch moto handlebar mounted on four-inch risers gives the overall look of the bike a Coastal style element that puts the rider in an aggressive posture on the bike.TANK STYLING
Features an FXLRS badge cover and a throw-back dropped “H” logo–like that seen on early H-D race bikes–adorns each side of the tank.2023 Harley Davidson Low Rider S/ST Photos
2023 Harley Davidson Low Rider S/ST Videos
2023 Harley Davidson Low Rider S Test Ride First Impressions
The 2023 Harley-Davidson Low Rider ST It’s not a Street or a Road Glide but let’s ride it anyway.
Harley-Davidson Official Websites
The post 2023 Harley Davidson Low Rider S/ST [Specs, Features, Photos] appeared first on webBikeWorld.
