The 2023 Harley Davidson Ultra Limited: Unlimited Horizons
For fans of the iconic Street Glide looking to improve two-up touring, then the 2023 Harley Davidson Ultra Limited is the machine to put a leg over.
Powered by the popular Milwaukee-Eight® 114 engine which is shared across the 2023 Harley Davidson lineup, it can easily handle the weight of passengers and all your gear. With 119 lbs-ft of torque, you’ll feel the power as the Ultra Limited carries you toward the horizon.
The Ultra Limited is loaded with features like a 6.5” TFT display, heated grips, cruise control, and Boom!
The Ultra Limited is one of Six limited-edition, serialized motorcycle models featuring commemorative paint, finishes, and premium features that celebrate 120 years of Harley Davidson pride and craftsmanship. It can be yours for a $3000 premium.
There is an amazing list of 8 color choices for the 2023 Harley Davidson Ultra Limited
- Vivid Black – Chrome Finish
- Redline Red – Chrome Finish
- Gray Haze / Silver Fortune – Chrome Finish
- Bright Billiard Blue / Billiard Gray – Chrome Finish
- Vivid Black – Black Finish
- Gray Haze – Black Finish
- Bright Billiard Blue / Billiard Gray – Black Finish
- Prospect Gold / Vivid Black – Black Finish
- Heirloom Red Fade
Check out the brand links below for the entire list of colors available.
The 2023 Harley Davidson Ultra Limited starts at $29,799 USD / $35,699 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Harley Davidson Ultra Limited in one place.
- Price: $29,799 USD / $35,699 CAD
- Milwaukee-Eight® 114 V-Twin engine
- Vented Batwing Fairing
- Two-Tone Paint Options
- Optional RDRS Electronics Package
- 120th Anniversary Edition
- Engine: 114 ci V-twin
- Power: 100.5 HP (estimated)
- Torque: 119 lbs-ft @ 3000 RPM
- Wet Weight: 917 lb. (416 kg)
- Seat Height: 27.5 in. (699 mm)
- Indian Roadmaster Limited
- BMW R18 Transcontinental
- Kawasaki Vulcan 1700 Voyager ABS
- Honda Goldwing Tour Automatic DCT
2023 Harley Davidson Ultra Limited Specifications
Engine | 114 cu in, Twin-Cooled |
Engine Torque | 122 ft-lb |
Bore x Stroke | 4.016 in. x 4.5 in. |
Compression Ratio | 10.5:1 |
Fuel System | Electronic Sequential Port Fuel Injection (ESPFI) |
Starter | |
Exhaust | 2-1-2 dual exhaust with tapered mufflers |
Clutch | |
Transmission | 6-speed |
Primary Drive | Gear, 34/46 ratio |
Front Fork | 49mm Dual Bending Valve |
Rear Shocks | Premium standard height hand-adjustable rear suspension |
Wheels, Front Type | Slicer II cast aluminum with clear coat |
Wheels, Rear Type | Slicer II cast aluminum with clear coat |
Brakes Front | 32 mm, Dual floating rotors |
Brakes Rear | 4-piston fixed |
Tires Front | BW 130/70B18 63H |
Tires Rear | BW 180/55B18 80H |
Fuel Tank Capacity | 6 gal. |
Color | Vivid Black w/Chrome Finish, Redline Red w/Chrome Finish, Gray Haze/Silver Fortune w/Chrome Finish, Bright Billiard Blue/Billiard Gray w/Chrome Finish, Heirloom Red Fade, Vivid Black w/Black Finish,Gray Haze w/Black Finish, Prospect Gold/Vivid Black w/Black Finish, Bright Billiard Blue/Billiard Gray w/Black Finish |
Ignition | |
Headlight | All LED headlamp |
Tail Light | LED |
Length | 102.3 in. |
Trail | 6.7 in. |
Rake | 26 |
Wheelbase | 64 in. |
Ground Clearance | 5.3 in. |
Seat Height | 27.5 in. |
Weight, As Shipped | 880 lb. |
Warranty | |
Extension |
2023 Harley Davidson Ultra Limited Features
BOOM!
BOX GTS INFOTAINMENT SYSTEMREFLEX
LINKED BREMBO® BRAKES WITH STANDARD ABS
Designed to help prevent the wheels from locking under braking to assist the rider in maintaining control when braking in a straight-line.VENTED BATWING FAIRING
The bold styled vented batwing fairing delivers smooth air flow and reduced head buffeting.TOURING FOR TWO
Equipped with a comfort seat for you and a passenger seat and backrest for your companion, saddle up and set out in maximum comfort.PREMIUM TOUR-PAK® LUGGAGE CARRIER
A sleek yet spacious Tour-Pak® luggage carrier with luggage rack that can easily house both rider and passenger helmets along with extra travel essentials.2023 Harley Davidson Ultra Limited Photos
2023 Harley Davidson Ultra Limited Videos
2023 Harley Davidson Ultra Limited 120th Anniversary Test Ride First Impressions
2023 Harley Anniversary Ultra Limited
Harley-Davidson Official Websites
The post 2023 Harley Davidson Ultra Limited [Specs, Features, Photos] appeared first on webBikeWorld.
