The Ultimate Urban Adventure: 2023 Kawasaki KLX 230SM
For 2023, Kawasaki motorcycles is in a class of 1 as far as smaller displacement super moto bikes being offered by Japanese motorcycle makers. The KLX 230SM is a versatile and exciting motorcycle that caters to both new and experienced riders. With a combination of aggressive styling, excellent performance, and ease of use, this supermoto bike has been designed to provide an enjoyable experience with a dependable 233cc air-cooled, fuel-injected, single-cylinder, four-stroke engine. The bike’s six-speed transmission ensures that there’s an appropriate gear for every situation, whether you’re navigating city streets or tackling twisty mountain roads.
Kawasaki’s 2023 lineup is full of bikes with great suspension and the KLX 230SM is no different. The bike features a 37mm telescopic fork with 8 inches of travel and a Uni-Trak® rear suspension with adjustable preload and 8.6 inches of travel. Braking on the KLX 230SM is handled by a 300mm petal-style front disc brake and a 240mm rear disc brake, both utilizing dual-piston calipers. ABS is available as an option and adds an extra layer of safety and control, particularly in wet or slippery situations.
The KLX 230SM features a lightweight, steel perimeter frame that contributes to its agile handling and responsive nature. The bike’s ergonomics have been designed with both comfort and control in mind, making it an excellent choice for riders of various sizes and skill levels. Lastly, the 2023 Kawasaki KLX 230SM boasts distinctive and aggressive styling. Its sharp lines and bold color options make it a head-turner on the streets, and its compact dimensions contribute to its nimble and lively character.
The 2023 Kawasaki KLX 230SM starts at $5,299 USD/ NA CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Kawasaki KLX 230SM in one place.
- Price: $5,299 USD/ NA CAD
- Large disc brakes
- Supermoto styling
- LED headlight
- ABS available
- Engine: 233cc 4-stroke single cylinder, SOHC, air-cooled
- Power: 19.74 horsepower
- Torque: 14.3 lb-ft
- Weight: 295 lbs (134 kgs)
- Seat Height: 33.3 inches (845 mm)
2023 Kawasaki KLX 230SM Specifications
Engine | 233cc, 4-stroke single, SOHC, air-cooled |
Power | 19.74 HP |
Bore x Stroke | 67.0 x 66.0mm |
Compression Ratio | 9.4:1 |
Fuel System | DFI® with 32mm Keihin throttle body |
Lubrication | |
Clutch | Wet multi-disc manual clutch |
Transmission | 6-speed, return shift |
Final Drive | Chain |
Suspension Front | 37mm telescopic fork/8.0 in |
Suspension Rear | Uni-Trak® linkage system and single shock with adjustable spring preload/8.6 in |
Brakes Front | Single 300mm petal disc with a dual-piston caliper (and ABS) |
Brakes Rear | Single 220mm petal disc with single-piston caliper (and ABS) |
Tires Front | 110/70-17 |
Tires Rear | 120/70-17 |
Fuel Tank Capacity | 2.0 gal. |
Color | Lime Green, Oriental Blue |
Ignition | TCBI Electronic Advance |
Headlight | LED |
Tail Light | LED |
Overall Length | 80.7 in. |
Overall Width | 32.9 in. |
Overall Height | 44.1 in. |
Wheelbase | 54.1 in. |
Ground Clearance | 9.1 in. |
Seat Height | 33.3 in. |
Curb Weight | NON ABS: 295.5 lb. / 297.7 lb. CA model, ABS: 297.7 lb. / 299.9 lb. CA model |
Warranty | 12 Months |
2023 Kawasaki KLX 230SM Features
ABS (Anti-lock Brake System)
Kawasaki ABS systems use front and rear wheel sensors to constantly monitor wheel speed. Should information from either of the sensors indicate that wheel lock has occurred, the ABS ECU directs the pump in the ABS unit to modulate brake fluid pressure (releasing and reapplying pressure so that traction can be regained) until normal operation resumes. ABS offers rider reassurance that contributes to greater riding enjoyment.2023 Kawasaki KLX 230SM Photos
2023 Kawasaki KLX 230SM Videos
2023 Kawasaki KLX 230SM review by Pitbike Mike:
Kawasaki Official Websites
The post 2023 Kawasaki KLX 230SM [Specs, Features, Photos] appeared first on webBikeWorld.
