The 2023 Suzuki Boulevard C50 Keeps the Cruiser Spirit Alive
Suzuki’s cruiser line may not be the most extensive in the market, especially compared to its Japanese competition, but the manufacturer’s two entries into the class – the M109R and the C50 are both excellent choices in their own regards. The tamer of the two bikes – the C50 is a pretty traditional cruiser by most standards, with a healthy dose of modern touches to keep it alive. The Boulevard C50 branding dates back to 2005, when Suzuki renamed its Volusia cruiser, and the C50 has remained a fan favorite ever since.
A unique name among the Suzuki line of motorcycles – the C50 ( and its M109R brother) measures its engine size in cubic inches like an American cruiser, rather than the standard cubic centimetres like the rest of Suzuki’s bikes – The 50ci ( actually 49.1ci) translates into 805cc. The “C” prefix in the C50 name simply stands for, you guessed it, Cruiser.
The bike’s liquid-cooled 805cc V-twin engine makes a very well-rounded 53hp and 52 lb-ft. Paired to that powerplant is a smooth five-speed transmission and a shaft drive sending power to the bike’s rear tire. Suzuki says the bike is set up for low-rpm torque to make riding in an urban environment more enjoyable.
When most bikers think of a Japanese motorcycle, they probably don’t jump right to a cruiser, but when looking at some of the competition, it’s needless to say that the 2023 Boulevard C50 is a great choice, with finishing touches like preload adjustable rear suspension, spoked chrome wheels, and a comfortable seat sitting at 27.6 inches high. The C50 is available in two packages – the standard cruiser C50 and the C50T, a touring-focused upgrade package which adds a tall windshield, leather saddlebags, and a more comfortable seat, as well as an exclusive paint option. The T package is an additional $1,450 USD/ $1,900 CAD
For 2023 the Suzuki Boulevard C50 can be purchased in either Solid Iron Gray or Candy Daring Red. The C50T package is only available in Pearl Brilliant White.
The 2023 Suzuki Boulevard C50 starts at $8,909 USD / $10,899 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc., so you can read up on the new 2023 Suzuki Boulevard C50 in one place.
Motorcycle Overview
- Price: $8,909 USD / $10,899 CAD
- 805cc V-Twin engine
- Optional Touring Package
- Shaft Drive
- Comfortable Riding Position
- Engine: 805cc V-Twin
- Power: 53hp
- Torque: 52 lb-ft
- Weight: 611 lbs (277 kg)
- Seat Height: 27.6 inches (700mm)
- Kawasaki Vulcan 900
- Yamaha Bolt R-Spec
2023 Suzuki Boulevard C50/C50T Specifications
Engine | |
Engine | 805cc, 4-stroke, Liquid-cooled, OHC, 45-degree V-twin |
Bore x Stroke | 83.0mm x 74.4mm (3.268 in. x 2.929 in.) |
Compression Ratio | 9.4 : 1 |
Fuel System | Suzuki Fuel Injection |
Lubrication | Wet sump |
Drivetrain | |
Transmission | 5-speed constant mesh |
Clutch | |
Final Drive | Shaft Drive |
Chassis | |
Suspension Front | Telescopic, coil spring, oil damped |
Suspension Rear | Link type, coil spring, oil damped |
Brakes Front | Disc brake |
Brakes Rear | Drum brake |
Tires Front | 130/90-16M/C 67H, tube type |
Tires Rear | 170/80-15M/C 77H, tube type |
Fuel Tank Capacity | 15.5 L (4.1 US gal.) |
Color | |
Electrical | |
Ignition | Electronic ignition (CDI) |
Spark Plug | |
Traction Control | |
ABS | |
Dimensions | |
Overall Length | 2500 mm (98.4 in) |
Overall Width | 955 mm (37.6 in) |
Overall Height | 1110 mm (43.7 in) |
Ground Clearance | |
Wheelbase | 1655 mm (65.2 in) |
Seat Height | 700 mm (27.6 in) |
Curb Weight | 277 kg (611 lbs) |
Warranty | |
Warranty | 12-month limited warranty |
Extension |
2023 Suzuki Boulevard C50/C50T Features
SUZUKI PROTECTION PLAN
Suzuki Protection Plan is a comprehensive plan that covers all mechanical, electrical and computer systems on your Suzuki Motorcycle or ATV. Ask your local Authorized Dealer about Suzuki Protection Plan for extra peace of mind.CLASSIC RUMBLE
Narrow, 805cc, fuel-injected, liquid-cooled, SOHC, four-valve-per-cylinder, 45-degree, V-twin engine is tuned for exceptional low rpm torque.SCULPTED ENGINE
Sculpted engine features polished aluminum and chrome covers that complement the visually striking cylinders with symmetrical cooling fins.DUAL EXHAUST SYSTEM
Chromed and staggered dual-exhaust system mounted on the right side of the engine is tuned for responsive torque delivery, providing a deep, rumbling exhaust note.SUSPENSION
The link-type rear suspension is shaped to mimic the hard-tail lines of a traditional cruiser, connecting a truss-style swingarm and a single shock absorber with seven-way spring preload adjustability, providing 4.1 inches of smooth and responsive suspension travel.WHEELBASE
A kicked-out, 33-degree rake and long 65.2-inch wheelbase provide a smooth, comfortable ride.MODERN COMFORT
Wide handlebars, forward-mounted floorboards, and leather-textured seats provide a comfortable ride around town and on the highway.HEADLIGHT AND TAILLIGHT
A bright multi-reflector headlight is paired with a durable, efficient, and compact LED taillight.INTRUMENT CLUSTER
The instrument cluster includes a convenient gear-position indicator, a large fuel meter, and a clock.TURN SIGNALS
Rear turn signals are mounted at the base of the rear fender to allow room for adding saddlebags.2023 Suzuki Boulevard C50/C50T Photos
2023 Suzuki Boulevard C50/C50T Videos
The Truth about the Suzuki C50 Boulevard by Cruisin the Narrow Road:
SUZUKI Motorcycles Websites
The post 2023 Suzuki Boulevard C50/C50T [Specs, Features, Photos] appeared first on webBikeWorld.
