The 2023 Suzuki Burgman 400 Is A Comfortable Sophisticated Scooter
The Suzuki Burgman Scooter family has been around for over 2 decades and has remained an international favourite for scooter riders. While Suzuki’s motorcycles are often regarded for its performance bikes, the Burgman is known to offer its riders a sense of poise and refined class for commuting instead of the blistering speed that the likes of the Hayabusa may offer. Not much has changed for this year’s iteration of the Suzuki Burgman 400, but it’s still a great package and has its place in the 2023 Suzuki lineup.
The Burgman 400’s body features a modern, sleek, and aerodynamic design. The bike has a standard 2-up style seat and an adjustable backrest to accommodate a passenger. Underneath the seat is a 50-litre storage space large enough for two helmets or anything the rider desires. Built into the bodywork is a hidden anti-theft device – a pass-through which allows a chain to be looped around the frame as a means of securing the Burgman. The scooter is powered by a liquid-cooled 400cc single-cylinder engine, which produces about 30hp. Like most scooters, power is transferred to the rear wheel through a CVT transmission. The ride is kept comfortable yet sporty with 41mm front forks and a 7-way adjustable mono rear shock.
Made in Japan, the Burgman 400 inherits heaps of technology from its Suzuki brethren, including traction control, ABS. and the Suzuki easy start system, which lets the scooter start quickly and easily with a single press of the starter button and the brake applied. Additionally, the Burgman comes standard with LED headlights, front position lights, and rear combination lights. Located just below the handlebars is a small storage area with a built-in 12V outlet, which can be used to charge your phone while you ride.
The instrument cluster is a combination analog/LCD unit, which combines modern technology with timeless design.
In the United States, the Burgman 400 is only available in Solid Iron Gray. Up north, the Canadian variant is offered in Metallic Matte Black.
The 2023 Suzuki Burgman 400 starts at $8,599 USD / $9,899 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Suzuki Burgman 400 in one place.
Motorcycle Overview
- Price: $8,599 USD / $9,899
- Peppy 400cc single-cylinder engine
- Sleek styling
- Rear 7-way adjustable link-type mono-shock
- Spacious 50-litre underseat storage.
- Engine: 400cc single cylinder
- Power: 30hp
- Torque: ?
- Weight: 474 lbs (215kg)
- Seat Height: 29.5 inches (755mm)
- Yamaha XMAX
- BMW C 400 GT
2023 Suzuki Burgman 400 Specifications
Engine | |
Engine | 400cc, 4-stroke, liquid-cooled, single-cylinder, DOHC |
Bore x Stroke | 81.0 mm x 77.6 mm (3.2 in x 3.1 in) |
Compression Ratio | 10.6:1 |
Fuel System | Suzuki Fuel Injection |
Lubrication | Wet sump |
Drivetrain | |
Transmission | Automatic CVT |
Clutch | |
Final Drive | V-belt Drive |
Chassis | |
Suspension Front | Telescopic, coil spring, oil damped |
Suspension Rear | Link type, coil spring, oil damped |
Brakes Front | Twin Disc brake |
Brakes Rear | Disc brake |
Tires Front | 120/70-15 M/C 56S, tubeless |
Tires Rear | 150/70-13 M/C, 64S tubeless |
Fuel Tank Capacity | 13.5L (3.6 US gal) |
Color | |
Electrical | |
Ignition | Electronic ignition (CDI) |
Spark Plug | |
Traction Control | |
ABS | Motion Track Anti-lock Brake System with cornering ABS |
Dimensions | |
Overall Length | 2235 mm (89.2 in) |
Overall Width | 765 mm (29.9 in) |
Overall Height | 1350 mm (53.1 in) |
Ground Clearance | |
Wheelbase | 1580 mm (62.4 in) |
Seat Height | 755 mm (29.5 in) |
Curb Weight | 215 kg (474 lbs.) |
Warranty | |
Warranty | 12-month limited warranty |
Extension |
2023 Suzuki Burgman 400 Features
SUZUKI PROTECTION PLAN
Suzuki Protection Plan is a comprehensive plan that covers all mechanical, electrical and computer systems on your Suzuki Motorcycle or ATV. Ask your local Authorized Dealer about Suzuki Protection Plan for extra peace of mind.THE ELEGANT ATHLETE
It fits well, like a fine handmade suit. It rides comfortably and performs like a champion. It maneuvres brilliantly. And it delivers a winning combination of stylish design, practicality and convenience. The BURGMAN 400 – bringing greater class and pleasure to your journey. Like a top athlete in peak form, the BURGMAN 400 is lean, toned and ready to perform optimally, even on narrow, twisty, or congested streets. Not only are its front and rear end slimmer, sharper and sexier than ever, this BURGMAN remains true to its family name by offering a fine style that will turn as many heads out front of the office as it will in front of your favourite cafe or out on the road.LED REAR COMBINATION LIGHTS
The slim rear of the BURGMAN 400 features independent LED rear combination lights with the turn signals at their tips. It’s a sharply sculpted design that expresses elegance and agility.ELEGANT AND EFFICIENT LED HEADLIGHT DESIGN
The slim, elegant styling of the nose features sharply styled dual LED headlights with integrated LED position lights and turn signals mounted beneath. The overall effect creates a cleaner and lighter looking front end that is instantly recognizable as belonging to the BURGMAN family.LIGHT, LEAN AND LAVISHLY APPOINTED
The BURGMAN 400 makes no compromises on elegant styling, even while shedding weight over its predecessor. From the sharp, lean lines of it nose to the slim rear end, this BURGMAN clearly personifies fine craftsmanship, technological prowess, and dedication to quality.MULTI-FUNCTION INSTRUMENTATION
Large, easy-to-read analogue speedometer and tachometer dials flank a digital display that shows an odometer, dual trip meters, fuel gauge, coolant temperature indicator, average fuel consumption meter, ambient temperature indicator, freeze indicator*1 and clock. Also included is Suzuki’s Eco Drive Indicator, which come on when the vehicle is operated in a fuel-efficient manner and may help riders learn techniques to better economize on fuel*2.SIT IN THE LAP OF LUXURY
The stepped dual seat offers luxurious comfort for rider and passenger alike by combining a cushion that is 20mm thicker and a shape that is slimmer than on the current model. Double stitching adds a distinctively fashionable accent.RIDER BACKREST
The rider’s backrest can be adjusted 15mm or 30mm forward to provide optimal support and comfort for riders of various builds on longer outings.RICH UNDERSEAT STORAGE SPACE
The BURGMAN 400’s spacious 50-litre underseat storage:*1 compartment can hold two helmets
*2 and provides ample room for stowing your gear.
LUXURIOUS FRONT STORAGE
Two front compartments provide 3.5 litres:*1 of storage space on the right side and 2.8 litres
*2 on the left side for maps and other items
BRINGING MORE POWER TO THE RIDER
The right storage bay has a 12V DC outlet* for charging your mobile phone or other electronic devices.2023 Suzuki Burgman 400 Photos
2023 Suzuki Burgman 400 Videos
Suzuki Burgman 400 | The Argument for Maxi Scooters by Big Rock Moto:
Suzuki Burgman 400 Review by Visordown Motorcycle Video:
SUZUKI Motorcycles Websites
The post 2023 Suzuki Burgman 400 [Specs, Features, Photos] appeared first on webBikeWorld.
