The 2023 Zero FXE Introduces Riders To Thrilling Electric Motorcycles
The Zero FXE is the Supermoto option in the 2023 Zero Motorcycles lineup and is built on the groundbreaking Zero ZF 75-5 powertrain and Cypher II operating system, coupled with new LED head and tail lights. It also features a full-color, 5-inch TFT dash that outshines other American electric motorcycles well above its class. With a tap of a button, you can change riding profiles to conquer city streets or your local supermoto track. It comes pre-programmed with Eco or Sport modes and can be connected to your mobile device to customize performance or to get stats on your ride.
The FXE weighs in at just 289 pounds thanks to its precision-built and light weight aluminum frame. It has no gears and clutch and features an upright riding position.
The heart of the FXE is its Z-Force 7.2kWh battery, designed to last and backed by a five-year, unlimited mileage warranty. It also features a Long Term Storage Mode to optimize the battery’s state of charge and further improve long-term battery health. Charging is easy and discreet. The 650W onboard charger can be plugged into any household outlet, and charge times can be significantly reduced by using optional Quick Chargers.
The FXE’s powerplant produces a whopping 78 foot-pounds of torque which challenges rival American Motorcycle brands in many categories. The air-cooled Interior Permanent Magnet (IPM) motor delivers impressive performance and fierce acceleration. It works in conjunction with regenerative braking to channel energy back into the battery.
The Bosch anti-lock brake system (ABS) ensures confident braking and is available in other bikes that Zero offers. This system optimizes deceleration under hard braking, with levers that can be adjusted for improved ergonomics. The ABS can be switched on or off by the rider, giving you full control of your ride..
It boasts a city range of 100 miles and a highway range of 60 miles at 55 mph. It packs a punch with a peak torque of 78 ft-lb and a peak power of 46 horsepower. It can reach a maximum top speed of 85 mph and a sustained top speed of 75 mph. It also features a Showa 41mm inverted cartridge forks at the front and a Showa 40mm piston piggy-back reservoir shock at the rear, offering impressive suspension travel of 7 inches at the front and almost 9 inches at the rear. The seat height is a comfortable 32.9 inches, perfect for riders of different sizes.
The 2023 Zero FXE starts at $11,995 USD/$15,445 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Zero FXE in one place.
Motorcycle Overview
- Price: $11,995 USD/$15,445 CAD
- 100 mile range with 9.7 hour standard charge time
- 85 mph top speed
- 550 amp, 3-phase brushless controller with regenerative deceleration
- Zero App and Cypher Store
- Engine: Z-Force® 75-5 air-cooled, radial flux, interior permanent magnet, brushless motor
- Power: 46 horsepower
- Torque: 78 ft-lbs
- Weight: 298 lbs (135 kgs)
- Seat Height: 32.9 inches (836 mm)
2023 Zero FXE Specifications
Motor | |
Peak torque | 78 ft-lb (106 Nm) |
Peak power | 46 hp (34 kW) @ 4,300 rpm |
Top speed (max) | 85 mph (137 km/h) |
Type | Z-Force® 75-5 passively air-cooled, high efficiency, radial flux, interior permanent magnet, brushless motor |
Controller | High efficiency, 550 amp, 3-phase brushless controller with regenerative deceleration |
Lubrication | |
Drivetrain | |
Transmission | Clutchless direct drive |
Clutch | |
Final Drive | 90T / 18T, Poly Chain® HTD® Carbon
Chassis | |
Suspension Front | Showa 41 mm inverted cartridge forks, with adjustable spring preload, compression and rebound damping |
Suspension Rear | Showa 40 mm piston, piggy-back reservoir shock with adjustable spring preload, compression and rebound damping |
Brakes Front | Bosch Gen 9 ABS, J-Juan asymmetric dual piston floating caliper, 320 x 5 mm disc |
Brakes Rear | Bosch Gen 9 ABS, J-Juan single piston floating caliper, 240 x 4.5 mm disc |
Tires Front | Pirelli Diablo Rosso II 110/70-17 |
Tires Rear | Pirelli Diablo Rosso II 140/70-17 |
Fuel Tank Capacity | N/A |
Color | |
Power system | |
Power pack | Z-Force® Li-Ion intelligent integrated |
Charger type | 650 W, integrated |
Charge time (standard) | 9.7 hours (100% charged) / 9.2 hours (95% charged) |
Dimensions | |
Wheelbase | 56.0 in (1,422 mm) |
Overall Width | |
Trail | 2.8 in (71 mm) |
Rake | 24.4° |
Seat Height | 32.9 in (836 mm) |
Curb Weight | 298 lb (135 kg) |
Warranty | |
Warranty | 2 years |
Extension |
2023 Zero FXE Features
DESIGN
Zero partnered with Bill Webb in 2018 on a Custom build of the Zero FXS. Ultimately we wanted to utilize the build to inspire elements of future Zero motorcycles. Many concept builds push the envelope so far it doesn’t translate to the reality of riding and functionality. Bill Webb took a different approach. He set out to create something that pushed the boundary but relatable and something that could become a reality. We were not surprised when the Motorcycle industry loved the bike. This enthusiasm went well beyond our industry.TECHNOLOGY
Built on the foundation of the revolutionary Zero ZF 75-5 powertrain and Cypher II operating system, the road before the FXE is always bright thanks to new LED head and tail lights as well as a full color and bonded TFT dash to literally outshine motorcycles well above its station. Brains and brawn.PERFORMANCE PROFILE
Transform performance profiles with the press of a button to perfectly conquer city streets or your local supermoto track. The Zero FXE is pre-programmed with Eco or Sport modes. Connect using your mobile device to customize performance or get stats on your ride.EXPERIENCE
The FXE is lighter than any motorcycle with this much power, has no gears and clutch, and an upright riding position making it the most user-friendly vehicle on the road. This bike truly becomes a seamless extension of the rider. Gliding effortlessly through traffic has never been so fun. The FXE is the motorcycle that rides as smooth as it looks.ACCESSIBLE
The most affordable new model from Zero Motorcycles, worldwide leader in electric motorcycles.2023 Zero FXE Photos
2023 Zero FXE Videos
2023 Zero FXE Review by RevZilla:
2023 Zero FXE review by TFLbike:
Zero Motorcycles Websites
The post 2023 Zero FXE [Specs, Features, Photos] appeared first on webBikeWorld.
