mariopoland
I have a problem with dct. I changed the pin shifter and the problem remained. the oil was changed to the appropriate one, the level was correct, the gearshift motor was cleaned. when the engine is cold and not warmed up, when shifting from 2nd to 3rd gear, the gears are lost and a line appears on the display. after warming up the engine, you can drive several hundred kilometers and it's OK, both on d and on s and on the manual, and the problem does not occur, everything works as it should, if the engine stops again for about half an hour and cools down, the problem returns, tested on 5 thousand kilometer, the problem is still the same and nothing changes. I can't diagnose what could be the problem. Has anyone had a similar case?
