preyj
Has any one put on a side stand plate extension? I am looking for a bit more surface area with the warm weather and fresh asphalt season approaching.
Jeff
Jeff
Jeff
Soupy's offers a bolt on one for their adjustable kickstand, 2.5" diameter.. Shouldn't be too noticeable when the stand's up.
http://www.soupysperformance.com/i/tn_2013-02-20_150825resize.jpg
The adjustable sidestand cost $150.....it should come with it already installed.
Not quite, but almost as bad! $139 actual cost for the side stand.. Mind you, it is cool looking.
Add a boot lace to it to loop over your handlebar. You'll never ride off and forget it and you can easily retrieve it after you've already gotten on the bike.
Have one end tied to the plate, and the other end to something inside the trunk (maybe the rubber strap holding the non-existent tool kit in place). Use that thin para cord or whatever its called and you can close the trunk over the cord while parked. That way there's even less to remember.
