2023 Can-Am Spyder F3 [Specs, Features, Photos]
The 2023 Can-Am Spyder F3: Time To Flex!
The Spyder F3 series from Can-Am is all about bold muscular styling on three wheels. All models push the performance envelope thanks to the European-made, 115 hp, Rotax® 1330 ACETM in-line 3-cylinder engine.
Can-Am equips the F3 trim level with a 6-speed semi-automatic gearbox and double wishbone front suspension featuring Sachs shocks both front and rear. Brembo brakes, traction and stability controls, and a hill hold feature round out a robust base machine.
This version of the Spyder F3, the first of the F3s in the 2023 Can-Am lineup, is stripped bare to focus on maximum performance from each of the 115 hp. Delivered with just a solo saddle, the Spyder F3 can be fine-tuned for the owner thanks to the UFIT System. This allows the rider and machine to be fitted to each other in both height and ergonomic positioning.
2023 Can-Am Spyder F3 colors: Steel Black Metallic
The 2023 Can-Am Spyder F3 starts at $18,499 USD / $23,099 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Can-Am Spyder F3 in one place.
2023 Can-Am Spyder F32023 Can-Am Spyder F3
Motorcycle Overview​
  • Price: $18,499 USD / $23,099 CAD
    • Muscular design
    • Sachs shocks front and read
    • Semi-automatic transmission with reverse mode
    • UFIT System
  • Engine: Rotax® 1330 ACE
    in-line 3 cylinders,
  • Power: 115 hp (85.8 kW) @ 7250 RPM
  • Torque: 96 lb-ft. (130.1 Nm) @ 5000 RPM
  • Dry Weight: 899 lb (408 kg)
  • Seat Height: 26.6 in. (675 mm)
2023 Can-Am Spyder F3 Specifications​
Engine​
Engine displacement
1330 cc
Type
Rotax® 1330 ACE
in-line 3 cylinders, liquid-cooled with electronic fuel injection and electronic throttle control
Bore & stroke
3.31 x 3.14 in. (84 x 80 mm)
Power
115 hp (85.8 kW) @ 7,250 RPM
Torque96 lb-ft. (130.1 Nm) @ 5000 RPM
Lubrication
Drivetrain​
TransmissionSE6
TypeSemi-automatic with reverse function
Gears6-speed
Chassis​
Suspension FrontDouble A-arms with anti-roll bar
Suspension RearSwing-arm
Brakes Front270 mm discs with Brembo† 4-piston fixed calipers
Brakes Rear
270 mm disc, 1-piston floating caliper with integrated parking brake
Tires FrontMC165/55R15 55H
Tires Rear
MC225/50R15 76H
Fuel Tank Capacity7.1 gal (27 L)
Color
Safety and Security​
ABSAnti-lock Braking System
Anti-theft systemDigitally Encoded Security System (D.E.S.S.
HHCHill Hold Control
Dimensions​
L x W x H
104 x 58.9 x 43.3 in. (2,642 x 1,497 x 1,099 mm)
Wheelbase67.3 in. (1,709 mm)
Seat height26.6 in. (675 mm)
Ground clearance
4.5 in. (115 mm)
Dry weight899 lb (408 kg)
Curb Weight
Warranty​
Warranty
2-year BRP Limited Warranty with 2-year roadside assistance
ExtensionB.E.S.T. extended service term available from 12 to 36 months.
2023 Can-Am Spyder F3 Features​
Features​
2 halogen headlamps (55/60 W)
Front fenders with integrated LED lights
Black perforated seat
Mono seat cowl
2023 Can-Am Spyder F3 Photos​
2023 Can-Am Spyder F3 2023 Can-Am Spyder F3 2023 Can-Am Spyder F3 2023 Can-Am Spyder F3
2023 Can-Am Spyder F3 Videos​
2023 Can-Am Spyder F3: The Ultimate Three-Wheeled Thrill Ride!
Harley Rider Tests Out A Can Am Spyder For The First Time
Can-Am Websites​
The post 2023 Can-Am Spyder F3 [Specs, Features, Photos] appeared first on webBikeWorld.
