2023 Can-Am Spyder RT Limited [Specs, Features, Photos]
Explore The Open Road With The 2023 Can-Am Spyder RT Limited and Sea-To-Sky
Can-Am dominates the 3-wheeled space with the Spyder RT Limited. It is a powerhouse of a machine that is revolutionizing the three-wheeler motorcycle world. The first thing you notice about the Can-Am Spyder RT Limited is its unique, eye-catching design. One of the Limited’s many impressive features is the clutchless gear changes that are accomplished via switches under the left grip. It also has a reverse gear. It is powered by a three-cylinder Rotax 1330 ACE engine commanding 115 horsepower and 96 lb-ft of torque.
The Spyder RT Limited is also about safety and includes a vehicle stability system (VSS) and anti-lock braking system (ABS) as standard. Adding to the comfort of this tourer are features like an adjustable seat height, self-leveling rear air suspension, premium passenger backrest and heated seats and grips.
On the tech side, The Spyder RT Limited features a large, panoramic 7.8-inch LCD display and is equipped with the BRP GO! technology that allows riders to use their favorite apps while riding, including Genius Map and Sygic directions, and the popular live digital music platform Dash Radio1.
The Spyder RT Limited model features electronically-controlled power steering for easy handling. The power steering responds with more or less assistance depending on the speed. Also in the handling department, the front and rear SACHS suspension will keep your ride composed and in control at all times. The Spyder RT is equipped with a Digitally Encoded Security System (D.E.S.S.) as a standard anti-theft system. Without the specific coded D.E.S.S. key, a Spyder RT won’t start!
While the Limited is overflowing with features, the top of the line in the 2023 Can-Am lineup is the Sea-To-Sky model. For about $3k more, you get exclusive paint, 16-spoke prosecco wheels and other visual enhancements. The seats get upgraded foam with lumbar support. Adding to the visual appeal are the Sea-to-Sky stitched seats and special badging. Lastly, it includes adjustable side wind deflectors for a sportier look.
The 2023 Can-Am Spyder RT Limited starts at $28,499 USD / $34,499 USD (CAD) – Sea-To-Sky $30,999 USD / $37,499
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Can-Am Spyder RT Limited in one place.
2023 Can-Am Spyder RT Limited2023 Can-Am Spyder RT Limited
Motorcycle Overview​
  • Price: $28,499 USD / $34,499 USD (CAD) – Sea-To-Sky $30,999 USD / $37,499
    • Touring equipment added
    • 47 Gallon storage capacity
    • Premium LED headlights, 7.8” screen
    • BRP 6 speaker audio
  • Engine: 1330 cc Rotax in-line 3 cylinders liquid-cooled
  • Power: 115 horsepower
  • Torque: 96 lb-ft
  • Weight: 1,021 lbs (464 kgs)
  • Seat Height: 29.7 inches (1,714 mm)
2023 Can-Am Spyder RT Limited Specifications​
Engine​
Engine displacement
1330 cc
Type
Rotax® 1330 ACE
in-line 3 cylinders, liquid-cooled with electronic fuel injection and electronic throttle control
Bore & stroke
3.31 x 3.14 in. (84 x 80 mm)
Power
115 hp (85.8 kW) @ 7,250 RPM
Torque96 lb-ft. (130.1 Nm) @ 5000 RPM
Lubrication
Drivetrain​
TransmissionSE6
TypeSemi-automatic with reverse function
Gears6-speed
Chassis​
Suspension FrontDouble A-arms with anti-roll bar
Suspension RearSwing-arm
Brakes Front270 mm discs with Brembo† 4-piston fixed calipers
Brakes Rear
270 mm disc, 1-piston floating caliper with integrated parking brake
Tires FrontMC165/55R15 55H
Tires Rear
MC225/50R15 76H
Fuel Tank Capacity7 gal (26.5 L)
Color
Safety and Security​
ABSAnti-lock Braking System
Anti-theft systemDigitally Encoded Security System (D.E.S.S.
HHCHill Hold Control
Dimensions​
L x W x H
111.5 x 61.2 x 57.6 in. (2,833 x 1,554 x 1,464 mm)
Wheelbase67.5 in. (1,714 mm)
Seat height29.7 in. (755 mm)
Ground clearance
4.5 in. (115 mm)
Dry weight1,021 lb (464 kg)
Curb Weight
Warranty​
Warranty
2-year BRP Limited Warranty with 2-year roadside assistance
ExtensionB.E.S.T. extended service term available from 12 to 36 months.
2023 Can-Am Spyder RT Limited Features​
Features​
Rider Touring Floorboards
Adjustable passenger footboards
Ultra comfortable limited seat with lumbar support
Audio control keypad
Glove box with USB
Cruise control
Integrated hard-side luggage
Adjustable Electric Windshield with Memory
Calibrated for towing a Can-Am trailer
Signature LED lights
Driver and passenger heated grips
Driver and passenger heated seats
LinQ compatible top case with passenger backrest
2023 Can-Am Spyder RT Limited Photos​
2023 Can-Am Spyder RT Limited 2023 Can-Am Spyder RT Limited 2023 Can-Am Spyder RT Limited 2023 Can-Am Spyder RT Limited
2023 Can-Am Spyder RT Limited Videos​
2023 Can-Am Spyder RT Limited Review by Sledaddicz:
2023 Can-Am Spyder RT Sea-To-Sky Review by Shawn Smoak:
Can-Am Websites​
The post 2023 Can-Am Spyder RT Limited [Specs, Features, Photos] appeared first on webBikeWorld.
