2023 Kawasaki Z650 [Specs, Features, Photos]
The Z650 Is A High Performance Lightweight Standard
The 2023 Kawasaki Z650 is one of several naked motorcycles that Kawasaki has available. It delivers a great balance of power, handling, and comfort. With its sleek design and advanced technology, this bike is designed for riders who are looking for a high-performance motorcycle that is both fun to ride and easy to handle. At the heart of the Kawasaki Z650 is a liquid-cooled engine that delivers impressive performance. This 649cc engine is capable of producing up to 67 horsepower and 48 lb-ft of torque, making it a powerful choice for riders who want a thrilling ride.
One impressive feature of the Z650 is its lightweight chassis. Weighing in at just 410 pounds, this bike is incredibly nimble and easy to handle, making it ideal for riders of all skill levels. Additionally, the chassis features a steel trellis frame that provides excellent rigidity and stability, which helps to ensure that riders can stay in control even at high speeds.
Kawasaki’s 2023 lineup of motorcycles includes the latest technology and the Z650 is no different. This bike comes equipped with a full digital instrumentation that includes a tachometer, speedometer, odometer, trip meter, fuel gauge, and more. The Z650, while naked, still also packs advanced safety technology such as Anti-lock Brakes (ABS) as standard. Finally, the Z650 features a comfortable seating position that makes it easy to ride for extended periods of time. The 2023 Z650 shows why Kawasaki is one of the top Japanese motorcycle manufacturers and delivers an impressive motorcycle that delivers great performance, handling, and comfort.
The 2023 Kawasaki Z650 starts at $7,749 USD/$9,499 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Kawasaki Z650 in one place.
2023 Kawasaki Z6502023 Kawasaki Z650
  • Price: $7,749 USD/$9,499 CAD
    • LED headlights
    • Smartphone Connectivity
    • TFT color screen
    • Horizontal Back-link Rear Suspension
  • Engine: 649 cc 4-stroke, 2-cylinder, DOHC, liquid-cooled
  • Power: 67.3 horsepower
  • Torque: 48.5 lb-ft
  • Weight: 410 lbs (185 kgs)
  • Seat Height: 31.1 inches (789 mm)
2023 Kawasaki Z650 Specifications​
Engine649cc, 4-stroke, 2-cylinder, DOHC, liquid-cooled
Power67.3 Hp
Bore x Stroke83.0 x 60.0mm
Compression Ratio
10.8:1
Fuel SystemDFI® with Keihin 36mm throttle bodies
Lubrication
Clutch
Transmission6-speed, return shift
Final DriveSealed chain
Suspension FrontTelescopic fork/4.9 in
Suspension RearHorizontal back-link with adjustable preload, swingarm/5.1 in
Brakes FrontDual 300mm petal-style discs with two-piston calipers, (and ABS)
Brakes Rear
Single 220mm petal-style disc, (and ABS)
Tires Front120/70 ZR17
Tires Rear160/60 ZR17
Fuel Tank Capacity4.0 gal
Color
Metallic Spark Black/Metallic Flat Spark Black, Metallic Matte Graphenesteel Gray/Ebony
IgnitionTCBI with electronic advance
HeadlightLED
Overall Length80.9 in
Overall Width30.1 in.
Overall Height41.9 in
Wheelbase55.5 in
Ground Clearance5.1 in
Seat Height31.1 in
Curb WeightNON ABS: 410.1 lb / ABS: 412.3 lb
Warranty12 Month Limited Warranty
Kawasaki Protection Plus12, 24, 26 or 48 months
2023 Kawasaki Z650 Features​
Assist & Slipper Clutch​
Dual Throttle Valves​
Economical Riding Indicator​
Smartphone Connectivity​
Clever technology enables riders to connect to their motorcycle wirelessly. Using the smartphone application “RIDEOLOGY THE APP,” a number of instrument functions can be accessed, contributing to an enhanced motorcycling experience. Vehicle information (such as the odometer, fuel gauge, maintenance schedule, etc) can be viewed on the smartphone. Riding logs (varies by model, but may include GPS route, gear position, rpm, and other information) can be viewed on the smartphone. When connected, telephone (call, mail) notices are displayed on the instrument panel. Riders can also make changes to their motorcycle’s instrument display settings (preferred units, clock and date setting, etc) via the smartphone. And on certain models, it is even possible to check and adjust vehicle settings (such as Rider Mode, electronic rider support features, and payload settings) using the smartphone.
ABS (Anti-lock Brake System)​
Horizontal Back-link Rear Suspension​
Compared to the Kawasaki traditional Uni-Trak® rear suspension, which mounts the shock unit vertically, with Horizontal Back-link Rear Suspension, the shock unit is almost horizontal. The original Kawasaki suspension arrangement locates the shock unit very close to the bike’s center of gravity, greatly contributing to mass centralization. And because there is no linkage or shock unit protruding beneath the swingarm, this frees up space for a larger exhaust pre-chamber (an exhaust expansion chamber situated just upstream of the silencer). With a larger pre-chamber, silencer volume can be reduced, and heavy exhaust components can be concentrated closer to the center of the bike, further contributing to mass centralization. The result is greatly improved handling.
2023 Kawasaki Z650 Photos​
2023 Kawasaki Z650 2023 Kawasaki Z650 2023 Kawasaki Z650 2023 Kawasaki Z650
2023 Kawasaki Z650 Videos​
2023 Kawasaki Ninja Z650 review by Peter Lowe one:
2023 Kawasaki Ninja Z650 Review by BenalRida:
Kawasaki Official Websites​
The post 2023 Kawasaki Z650 [Specs, Features, Photos] appeared first on webBikeWorld.
