yticolev
2012 NC700X manual transmission at 30K has developed a metallic cyclic scraping sort of noise which I believe must be the transmission. Initially I thought it was a kinked chain or misaligned rear wheel as the sound appeared to come with every wheel revolution (in first gear going slow). However timing of the sound remains roughly the same no matter the speed, which makes me think gear changes are involved. The sound is also located in the transmission area on the left side. Chain seems to be properly adjusted and no tight/loose things happening.
I hope to bring it to an independent certified Honda mechanic at some point this winter that I've used before. In any case, I need a new tire and it is time for a valve adjustment. Just hoping for some insight before bringing it in. Sounds expensive.
