2021 BMW R NineT [Model Overview]
The 2021 BMW R NineT: Unmistakable. Original. Air-cooled.​
The 2021 BMW R nineT is the flagship heritage model from European manufacturer BMW Motorrad. Though it has been a standard feature in the brand’s arsenal for many years, it has received a small update for 2021 to bring it in line with new emissions regulations. While the updates might be minimal, the R nineT is still one of the most exciting models in the 2021 BMW line-up.
The most noticeable updates for 2021 are minor engine tweaks. All of the models in the R nineT range use a 1,170cc air/oil-cooled, 4-stroke flat twin engine, and thanks to new and improved cylinder heads, the 2021 R nineT now produces a modest 109 horsepower and 86 lb-ft of torque. Even with new emissions compliance regulations, the R nineT is still a veritable powerhouse.
Top features of the new R nineT include ABS, Automatic Stability Control, adjustable rear suspension, adjustable USD front forks, spoked wheels, a chrome exhaust, and a sleek aluminum gas tank.
For 2021, the R nineT is available in four original BMW Motorrad color options: Black Storm Metallic; Black Storm Metallic / Vintage; Option 719 Pollux Metallic / Aluminum; and Option 719 Mars Red Metallic Matte / Cosmic Blue Metallic Matte.
The 2021 BMW R NineT starts at $15,495 USD / $17,500 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 BMW R NineT in one place.
2021 BMW R NineT
  • Price: $15,495 USD / $17,500 CAD
    • Boxer twin engine
    • Steering damper
    • ABS
  • Engine: 1,170 cc air/oil-cooled 4-stroke flat twin engine
  • Power: 109 HP
  • Torque: 86 lbs-ft
  • Wet Weight: 489 lbs (222 kg)
  • Seat Height: 31.7 in (805 mm)
2021 BMW R NineT
2021 BMW R NineT Specifications​
Engine 1,170 cc air/oil-cooled 4-stroke flat twin engine
Engine Power110 Hp
Bore x Stroke101 mm x 73 mm
Compression Ratio12.0:1
Mixture controlElectronic fuel injection
Max Torque86 lb-ft (116 Nm) at 6,000 rpm
ClutchSingle dry plate clutch, hydraulically operated
TransmissionConstant mesh 6-speed gearbox with helical cut gears
DriveShaft drive 2.91:1
Suspension FrontUpside-down telescopic fork, Ø 46 mm
Suspension RearCast aluminum single-sided swing arm with BMW Paralever; central spring strut, spring pre-load hydraulically adjustable (continuously variable) via handwheel, rebound damping adjustable
Brakes FrontDual floating disc brakes, 4-piston calipers, diameter 320 mm
Brakes RearSingle disc brake, diameter 265 mm, dual-piston floating caliper
Tires Front120/70 ZR 17
Tires Rear180/55 ZR 17
Fuel Tank Capacity4.8 gal (18 l)
ColorBlack Storm Metallic
AlternatorThree-phase 720 W alternator
Battery12 V / 14 Ah, maintenance-free
Headlight
Tail LightLED Tail Light
Overall Length83.1” (2,110 mm)
Overall Width35.5” (900 mm)
Overall Height48.8” (1,240 mm)
Wheelbase58.5” (1,487 mm)
Castor4.2” (107.9 mm)
Seat HeightStandard Seat: 31.7″, Custom Front Seat: 31.3″
Unladen weight, road ready, fully fueled
489 lbs (222 kg)
Warranty
2021 BMW R NineT
2021 BMW R NineT Features​
Twin-cylinder boxer engine.​
Powerful and reliable: the heart of the R nineT. The boxer is more than just an engine – it is a statement, a lifestyle.
Steering damper.​
The elegant conical connection of the steering damper is an homage to the engineering skill and a sign of the love of design at BMW Motorrad.
Type plate.​
Who are you and where do you come from? The type plate of the R nineT reveals a lot more than just “Made in Berlin”.
Variable rear.​
Whether you are alone or traveling as a pair, with the variable rear, you define your R nineT’s look in just a few short steps.
Seat supports.​
Forged from solid aluminum, the seat supports form the focal point between the tank, seat and engine.
Pure aluminum.​
Unpainted, raw, high-quality. Numerous parts made of brushed aluminum give the R nineT an unmistakable look.
ABS.​
BMW Motorrad quality, combined with the latest safety technology, guarantee you a carefree riding experience.
Fender bracket.​
The solid aluminum struts from one cast nestle against the front-wheel cover.
2021 BMW R NineT Photos​
2021 BMW R NineT
2021 BMW R NineT
2021 BMW R NineT
2021 BMW R NineT
2021 BMW R NineT Videos​
BMW Official Websites​
The post 2021 BMW R NineT [Model Overview] appeared first on webBikeWorld.
